Go to primary content
Siebel CRM Fundamentals Guide
Siebel Innovation Pack 2016, Rev. A
E52425-01
  Go to Documentation Home
Home
Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
    View PDF
Online Help Keyboard Shortcuts
Table 15-2 lists the keyboard shortcuts you can use to access options available on the Help application-level menu.
Table 15-2 Online Help Keyboard Shortcuts
Action Keyboard Shortcut Context
Display the online help.
CTRL+H
Screen
Display information about a record.
CTRL+ALT+K
Record
Display technical support information, including system information.
CTRL+ALT+J
Application
