| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2016, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Table 15-3 lists the keyboard shortcuts you can use to navigate in the Siebel application.
Table 15-3 General Navigation Keyboard Shortcuts
| Action | Keyboard Shortcut | Context |
Go to the Site Map. |
CTRL+SHIFT+A |
Application |
Go to the application-level menu. |
CTRL+ALT+M |
Application |
Go to the screen tabs. |
CTRL+SHIFT+T (Siebel shortcut.) INSERT+CTRL+R (JAWS shortcut) Note that CTRL+SHIFT+T is the shortcut, but for JAWS users it is recommended that you use the INSERT+CTRL+R Region List command. Note that CTRL+SHIFT+T is not available in Google Chrome. |
Application |
Go to the view tabs. |
CTRL+ALT+T (Siebel shortcut) INSERT+CTRL+R (JAWS shortcut) Note that CTRL+ALT+T is the shortcut, but for JAWS users it is recommended that you use the INSERT+CTRL+R Region List command. |
Application |
Go to the subview tabs. |
CTRL+ALT+V (Siebel shortcut.) INSERT+CTRL+R (JAWS shortcut) Note that CTRL+ALT+V is the shortcut, but for JAWS users it is recommended that you use the INSERT+CTRL+R Region List command. Note that CTRL+ALT+V is not available in Google Chrome. |
Application |
Open the Cogwheel icon window on a list or form. |
CTRL+SHIFT+M CTRL+SHIFT+G Note that CTRL+SHIFT+M is not available on Mozilla Firefox. |
List, form |
Go to the next list or form. |
CTRL+SHIFT+] CTRL+ALT+] |
Application |
Go to the previous list or form. |
CTRL+SHIFT+[ CTRL+ALT+[ |
Application |
Open the Tasks pane. |
CTRL+SHIFT+Y |
Application |
Go to a tree applet. |
CTRL+SHIFT+4 |
Application |
Go to the previous tree applet node. |
UP ARROW |
Application |
Go to the next tree applet node. |
DOWN ARROW |
Application |
Go to the field for the visibility filter. |
CTRL+SHIFT+V |
Application |
