Siebel Product Administration Guide > Configurator Workflow and Method Reference > Siebel Configurator Workflow Reference >
Configurator Load Workflow
Configurator Load Workflow, shown in Figure 22, loads the complex product model into memory and displays the Siebel Configurator user interface.
Figure 22. Configurator Load Workflow
Workflow Description. This workflow does the following:
  1. Load Instance. Loads the Product line item data structure through EAI and creates the CxObj memory structure for it. This step calls LoadEAI Method, which is described in the Copy Service reference in Siebel Order Management Infrastructure Guide.
  2. Go to UI. Loads the Siebel Configurator user interface for the product.
Siebel Product Administration Guide Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices.
