Siebel Product Administration Guide > Siebel Configurator Technical Reference >
Specifying Keep Alive Time for Configuration Sessions
By default, product configuration sessions remain active indefinitely. They do not time out.
You can specify how long product configuration sessions remain active by setting the server parameter for Keep Alive Time. This parameter specifies the time in seconds that a session can remain idle before the session is timed out. The default value of -1 means that the session can remain idle indefinitely and will not be timed out. Table 49 shows this server parameter.
Table 49. Server Parameter for Auto Match
Parameter Name
Display Name
Data Type
Default Value
Description
eProdCfgKeepAliveTime
Product Configurator - Keep Alive Time of Idle Session
Integer
-1
The amount of time in seconds that a configuration session can remain inactive before the session is killed.
Siebel Product Administration Guide Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices.
