Siebel Product Administration Guide > Siebel Configurator Web Templates >
Siebel Configurator Web Templates for Open UI
Siebel Product Configurator in Open UI provides a set of Web templates that are enabled for responsive Web design. These templates provide the user with two panes, giving the user the choice of using a tab or wizard approach to customizing products.
As delivered, these Web templates must be used together and cannot be used with other Siebel Product Configurator Web templates.
These templates are described in Table 16.
Table 16. Open UI Web Templates for Siebel Product Configurator
File Name
Name
Description
ecfgproducttabs_v14.swt
Tab Product Theme OUI
The product tab theme displays the product configuration UI with tabs and with Previous and Next buttons to navigate between groups.
ecfggroupstandard_v14.swt
Standard Group Theme OUI
The group theme displays a div section (which is like a table row) for each relationship that is part of the group definition.
ecfgcontrolcomboprice_v14.swt
Combo Box with Price OUI
The control combo price theme displays the products that are part of the relationship as option items in a combo box.
sisomecfgbaseautorepricetwocol_v14.swt
SIS OM base Theme With Auto Pricing OUI
The base theme displays two parts in the configuration page. The right hand section displays the product details, pricing and any messages associated with the product configuration, and the left hand section displays the product configuration UI.
ecfgcontrolradioprice_v14.swt
Radio Buttons with Price OUI
The control radio price theme displays the products that are part of the relationship as option buttons.
ecfgcontrolcheckprice_v14.swt
Check Box with Price OUI
The control check price displays the products that are part of the relationship as check box options.
ecfgobjmessages_v14.swt
n/a
Called as include SWT.
This template controls the product related information that is displayed on the right hand section.
ecfgportheader_v14.swt
n/a
This template controls the header for the div section displayed for the relationship.
ecfgportfooter_v14.swt
n/a
This template controls the footer for the div section displayed for the relationship.
ecfgtoplevelbuttons_v14.swt
n/a
This template displays various action buttons that control the product configuration.
ecfgobjglobalsignals_v14.swt
n/a
This template displays the various messages that are generated during the configuration process.
Siebel Product Administration Guide Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices.
