| Siebel CRM System Administration Guide Siebel Innovation Pack 2016 E24823-01 |
![]() Previous |
![]() Next |
View PDF |
It is important to follow the correct sequence when starting or shutting down a Siebel CRM deployment, because several dependencies require that certain servers are running before others. Perform the following procedures to start or shut down your Siebel CRM deployment.
This procedure describes how to start a Siebel CRM deployment.
To start a Siebel CRM deployment
For more information about this task, see your database documentation.
Start the Siebel Gateway Name Server system service.
Start the third-party load balancing software, if applicable.
For more information about load-balancing, see Siebel Deployment Planning Guide and the Siebel Installation Guide for the operating system you are using.
Start any other third-party software, if applicable.
Start the Siebel Server system service.
The Siebel Server must connect to the Siebel Gateway Name Server and Siebel database on startup.
Related Topics
"Administering the Siebel Gateway Name Server System Service"
"Configuring Siebel Server Load Balancing"
"Administering the Siebel Server System Service"
Related Books
Siebel Security Guide
This procedure describes how to shut down a Siebel CRM deployment.
To shut down a Siebel CRM deployment
Shut down the Siebel Server system service.
When the Siebel Server system service is shut down, it shuts down server components and tasks before shutting down itself.
Note: To make sure that server components shut down properly, shut down Siebel Servers before shutting down the Siebel Server system service. |
Shut down the third-party load balancing software and any other third-party software, if applicable.
For more information about load balancing, see Siebel Deployment Planning Guide and the Siebel Installation Guide for the operating system you are using.
Shut down the Siebel Gateway Name Server system service
Note: Make sure that all of the Siebel Servers are shut down before shutting down the Siebel Gateway Name Server Service. |
Shut down the Siebel database.
Related Topics
"Shutting Down a Siebel Server"
"Siebel Server Manager Commands"
Related Books
