Siebel Database Upgrade Guide for DB2 for z/OS > Upgrade Files for Siebel Business Applications >
Target Tables Amended During PRET Processing
The PRET upgrade jobs perform operations on the target database tables listed in Table 22. You might want to back up these tables before you start the upgrade.
Table 22 shows the target tables amended by PRET upgrade processing, the type of amendment made, and the upgrade path affected.
Table 22. Tables Changed During PRET Processing
Type of Change Made
SIA Paths
S_FN_CRDT_RPT
Alter
SIA753
S_REGION
Alter
SIA753
Siebel Database Upgrade Guide for DB2 for z/OS Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices.
