Siebel Database Upgrade Guide for DB2 for z/OS > Creating the Siebel Staging Database >
Process of Creating the Staging Database
Upgrades: All upgrades. Environments: All environments. The process of creating the staging database involves performing the following tasks:
- Perform the prerequisite tasks described in Required Tasks before Creating the Staging Database.
- Create the DDL schema files that will be used to build the staging database by running the Database Configuration Wizard. See Creating the Staging Database Schema DDL Files.
- Transfer the staging DDL files generated in Step 2 to the z/OS host where they are applied. See Transferring the Staging DDL to the z/OS Host.
- Set up the z/OS environment for the staging and target database upgrades and create the staging database. See Preparing the z/OS Upgrade Environment and Creating the Staging Database.
- Drop interface tables and triggers. See Removing Interface Tables and Triggers.
