Using Siebel Tools > Using Siebel Tools > Using Editors in Siebel Tools >
Using a Layout Editor
Siebel Tools includes the following layout editors:
  • Applet Layout Editor
  • View Layout Editor
  • Web Page Layout Editor
  • Applet Menu Layout Editor
A layout editor allows you to do the following:
  • Add or map a control or list column to an applet layout.
  • Modify an existing view or create a new view. You can drag and drop an applet to the View Layout Editor. You can view a list applet, a form applet, or the container page in Preview mode.
  • Add or delete a control from a Web page template, modify a control property, or map a control to a placeholder.
  • Edit the menu structure of a Siebel application. You right-click an applet in the Object List Editor, and then click Edit Web Menus.
  • Preview an approximation of how Siebel CRM displays an applet or a Web page at run time.
For more information about using layout editors, see Configuring Siebel Business Applications.
To use a layout editor
  1. In the Object List Editor, locate the object that you want to modify.
    You can open a layout editor from an applet, view, or Web page. For more information, see Locating and Modifying Object Definitions in the Object List Editor.
  2. Right-click the object that you located in Step 1, and then click Edit Web Layout or Edit Web Menus.
Using Siebel Tools Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices.
