Using Siebel Tools > Using Siebel Tools > Using Workspaces in Siebel Tools >
Deleting Workspaces
You can delete the workspaces that you own, but you cannot delete the workspaces or parent workspaces that are owned by other users. In addition, workspaces that are in the status of Submitted for Delivery or Delivered cannot be deleted from the repository. To delete a workspace
- In the workspace dashboard, navigate to the Workspace explorer pane.
- Select the workspace that you want to delete and then right-click.
A list of available actions appears. These options are Open, Delete, Refresh, Docked, and Hide.
- Select the Delete option.
The selected workspace is removed from the Workspace explorer pane.
