Using Siebel Tools > Using Siebel Tools > Using Workspaces in Siebel Tools >
Refreshing the Workspace Explorer Pane
At the time you open the Workspace explorer pane, this pane lists all available workspaces that are in the database. After that, if other users use other workspace sessions to modify their workspaces in the same database, such as adding new workspaces or deleting the current ones, you need to refresh the Workspace explorer pane to display these changes. To refresh the Workspace explorer pane
- In the workspace dashboard, navigate to the Workspace explorer pane.
- Select the root (MAIN) workspace and then right-click.
A list of available options appears. These options are Open, Delete, Refresh, Docked, and Hide.
- Select the Refresh option.
The Workspace explorer pane is refreshed displaying the latest changes for all workspaces in the database.
