Using Siebel Tools > Using Siebel Tools > Using Workspaces in Siebel Tools >
Tracking Repository Object Changes in Workspaces
You can use the Modified Objects option under the Workspace menu to view the changes that you have made to objects in the current workspace. To track repository object changes in a workspace
- In Siebel Tools, navigate to the Workspace explorer pane.
- To see the list of modified objects in a workspace without opening a workspace, select that workspace and then select a version from the Workspace Version pane.
- To see only the changes in the repository, open a version of the workspace.
When you open a particular version, all versions below the selected version are also opened. For example, if the workspace dev_sadmin_demo has 10 versions and you open the fifth version, then you can view the repository changes of version one through version five.
- View the detailed changes in the Modified Objects pane.
The Modified Objects pane lists the object names, object types, and operations that were performed for each modified object.
This table describes the values listed in the Operation column on the Modified Objects pane.
Update |
Indicates an operation of updating a parent object record. Also indicates an operation of inserting, updating, or enabling the Inactive option for a child record. |
Insert |
Indicates an operation of inserting a new parent object record. |
Delete |
Indicates an operation of enabling the Inactive option for a parent object record. |
NOTE: You cannot delete any existing record in workspace-enabled objects, but the new objects that were created in the latest workspace version can be deleted in that version.
