Using Siebel Tools > Using Siebel Tools > Using Workspaces in Siebel Tools >
Performing the Checkpoint Version Process
The checkpoint operation commits the changes that you made to the current workspace version of the selected workspace and sets that version to be non-editable. After checkpointing the workspace, you are no longer able to make object changes to the current version of the workspace. All subsequent object changes will be tracked under the next version of the workspace. To perform a checkpoint workspace version process
- In Siebel Tools, select the Workspaces menu and then select the Checkpoint option.
The Enter Comment dialog box appears.
- Enter the comments, which will be displayed in the Comment column on the Workspace Versions pane.
- Click the OK button.
A message appears saying the checkpoint process is completed successfully.
After a workspace version is check pointed, its status changes to Checkpointed in the My Workspaces pane and the Submit for Delivery option for that workspace is enabled under the Workspaces menu.
