Using Siebel Tools > Using Siebel Tools > Using Workspaces in Siebel Tools >
Reverting to Previous Workspace Versions
When the changes that were made since the last checkpointed version of the workspace cause issues, you can revert or roll back to the most recent checkpointed version. You can also revert or rollback a checkpointed version to the previous checkpointed version.
- If you perform the revert process on a workspace with the status set to Edit-In-Progress or Checkpointed, then all changes that you made in the latest version are lost and the workspace reverts back to the last checkpointed version.
- If you perform the revert process on the first version of the workspace, then all changes that you made in the first version are lost and the status of the workspace reverts back to Created.
To revert to a previous version of a workspace
- In Siebel Tools, select the Workspace menu and then select the Revert option.
A revert confirmation appears.
- Click the Yes button to revert all change back to the last checkpointed version.
NOTE: All changes that were made in the latest version will be lost.
Alternatively, click the No button to cancel the revert operation.
