Using Siebel Tools > Using Siebel Tools > Using Workspaces in Siebel Tools >
Exporting Workspace Objects to Archive Files
You can export all workspace objects to an archive file, such as object definitions of the object types Business Component, Applet, View, Screen, Integration Object, Business Object, and so on. To export workspace objects to an archive file
- In the workspace dashboard, select and open a workspace.
- Select the Tools menu and then select the Export Workspace to Archive option.
The Export Workspace to Archive dialog box appears. By default, the Workspace To Version field always displays the latest version of the workspace.
TIP: Optionally, you can open a specific workspace version in the Workspace Version pane to export that workspace's object changes into an archive file. For example, when a workspace has ten versions and you want to export the workspace's object changes through the seventh version, you can open the seventh version in the Workspace Version pane and then click the Export Workspace to Archive option under the Workspace menu.
- On the Export Workspace to Archive dialog box, select one version from the Workspace From Version drop-down list.
- Click the Export button.
The Export to Archive File dialog box appears. The status bar in this dialog box indicates the child objects that are included in the export process. When the process finishes, this dialog box displays the top-level objects in the Objects to Archive list.
NOTE: If you attempt to export a workspace that has no changes to an archive, then an error message appears saying that no objects are modified to be exported.
