Using Siebel Tools > Using Siebel Tools > Using Workspaces in Siebel Tools >
Comparing Workspace Versions
You can use the Compare option under the Workspace menu to identify the changes that are made to the objects in two selected workspace versions. To compare workspace versions
- In the workspace dashboard, select the Workspace menu and then select the Compare option.
The Compare Workspace dialog box appears. In the First Selection group box, the value in the Workspace Name field is populated using the value of the opened workspace name and the Version field is populated using the value of the opened version of that workspace.
- In the Second Selection group box:
- Select a workspace name from the Workspace Name drop-down list.
- Select a version from the Version drop-down list (which includes all versions of the selected workspace.)
- Click the OK button.
The status bar indicates that the process is running. When the process finishes, the Compare Objects dialog box appears, displaying all top-level objects that have differences in the two selected workspace versions.
- Select one object that has such differences.
The Compare Objects dialog box displays the object properties, including the similarities and the differences for each attribute.
- Close the Compare Objects dialog box by clicking the Close button.
