Product Overview
The security guidelines in this document apply to Oracle's Quad Port 10GBase-T Adapter. The
adapter is a standalone PCIe 3.0 x8 card that can be low profile or full height. This
adapter has four independent ports, and you can configure and operate each port a
different speed. An RJ45 Ethernet cable connects to each port. The adapter is used for
virtualized cloud deployments and network virtualization.
Data rate supported per port
Bus type
PCIe 3.0, 8.0 GT/s
Bus width
x8, x4, x1 lane PCIe
Conforms to Ethernet standard
802.3
Boot ROM
32 Mb Flash
Electromagnetic interference (EMI)
FCC Class A
