5000000000000002 - Server Application Process Error
This alarm indicates that either the minimum number of instances for a required process are not currently running or too many instances of a required process are running.
Recovery
  1. Contact the My Oracle Support (MOS).
  2. If a 3000000000000020 - Server Platform Process Error alarm is also present, execute the recovery procedure associated with that alarm before proceeding.
  3. Log in to the LSMS CLI using root password.
  4. Stop the LSMS application.
  5. Start the LSMS Application.
  6. Capture the log files on both LSMSs (see Saving Logs Using the LSMS GUI or Command Lineand contact the My Oracle Support (MOS).
