| Oracle® Retail Advanced Inventory Planning Order Management User Guide Release 14.1 |
![]() Previous |
![]() Next |
This chapter provides an introduction to using AIP.
How you access AIP depends on how the application is set up at your location. Contact your system administrator for instructions. After starting the application, you are prompted to log in. Your system administrator assigns a user name and a temporary password. You will need to change the password after you log on the first time. Additionally, you password periodically expires, in a period of time as determined by your system administrator.
The following rules apply when you change your password:
Passwords must be a minimum of six (6) characters and maximum of 128.
Passwords must contain at least five different characters.
Passwords must not be simple.
Cannot include sequences such as ABCDE or ABCXYZ.
Cannot contain more than four consecutive identical characters.
Passwords cannot be based on your user name or your full name.
Passwords cannot be based on a previous password.
Passwords cannot be based on a dictionary entry.
Perform the following steps to log on to AIP:
On the Login window, enter your user ID in the User Name field.
In the Password field, enter your password.
Click Log In.
In the Applications area, click AIP Online. The User Console is displayed.
Note: The User Console may be displayed when you log in. If this is the case, proceed to the next step. |
Select the application you want to use.
Click Start. The application opens in a new window.
When launching this application, you may see the Security Warning shown in Figure 2-1. Click Don't Block to continue.
Perform the following steps to change your password:
Log on to Oracle Retail Advanced Inventory Planning (AIP).
On the User Console, click Applications.
Click Change Password.
In the Current Password field, enter the password you used to log in to the applications
In the New Password field, enter the password you want to use in the future.
In the Retype password field, enter the password you entered in the New Password field.
Note: To cancel your changes, click the ”Return to front page without changing password” link. |
After logging into AIP, you have access to the application window. The primary elements in the application window are shown in Figure 2-2.
A - Title Bar
Located at the top of the application window. The title bar displays the product name and the area you are currently working in. The three buttons at the far right on the title bar allow you to minimize, restore, maximize, and close the application window.
B - Menu Bar
Located below the title bar. The menu bar provides access to different areas of the application.
C - Primary Tabs
Located at the top of the workspace. The primary tabs give you access to the functional areas available for the selections you made from the menu.
D - Secondary Tabs
Located in the workspace, beneath the primary tabs. The secondary tabs give you access to the functional area within each primary tab, if they exist for a specific tab.
E - Standard Buttons
Located at the left of the workspace. The standard buttons are enabled based on the work you have done or the selections you make in the workspace.
The basic method for entering data in a text field is to type the text in the field. Some fields, however, restrict the type of data that may be entered. The options for entering or selecting data depend on the type of data that may be required or permitted in the field. For example, some fields permit only numeric data, while others permit only alphabetic or alphanumeric data. Some fields require a date to be entered in a specific format. Some fields permit only one value, while others permit multiple values.
Calendars, drop-down lists and lists of value provide you with access to preformatted, predefined values. The following sections provide instructions for using these tools.
To look up the date, you can access a date picker window.
Perform the following steps to select a date:
Click the calendar button next to a date field. The calendar window opens.
Note: The calendar button appears as a drop down button to the right of the date field. |
Select the desired date:
To select a year, press the left or right arrows next to the year field.
To select a month, click the appropriate month abbreviation.
To select a day of the month, click the day on the calendar.
Click OK. The date field is automatically filled in when you select the day of the month.
Some fields are restricted to a predefined list of values. You access a drop-down list from which you can pick the desired value.
Click the drop-down button next to a field. A list of predefined values appears.
If necessary, scroll through the list until the appropriate value appears.
Select the value. The field is automatically filled in with the selected value.
Some fields are filtered by the selections you have made in a previous field. These fields are indicated by arrows pointing to them from other fields.
Note: Any fields that are required when searching are indicated with an asterisk (*). |
In the example:
Table 2-1 Example of Field Level Filters
| Field Name | Results in Limits To | Indicated By |
Order Source, Class, and Demand Group |
SKU |
Black arrow |
Class |
Demand Group |
Green arrow |
SKU |
Order Source |
Blue arrow |
Note: The colors indicated are specific to this example. The arrows in the window you are working in may be colored differently and serve only to help you distinguish the different lines. |
After you make a selection, the clear List of Values (LOV) button is enabled. If two fields filter each other as part of a field-level filter, you must clear your selections before you can make additional selections. To clear the field, click the LOV button.
When certain elements are selected, related fields are filtered to only display data corresponding with the selected element. The following sections detail the impact of selection on these related fields.
When Demand Group is selected, the following field is filtered:
SKU - Filtered to only display SKUs having a pack-size in the selected demand group.
When Profile is selected, the following field is filtered:
Class - Filtered to only display classes containing a SKU assigned to the selected profile.
When SKU is selected, the following fields are filtered:
Demand Group - Filtered to only display demand groups containing a pack-size of the selected SKU.
Order Source - Filtered to only display suppliers that supply a pack-size of the selected SKU, and warehouses that are ranged for a pack-size of the selected SKU.
When Class is selected, the following fields are filtered:
Demand Group - Filtered to only display demand groups containing a SKU belonging to the selected class.
SKU - Filtered to only display SKUs belonging to the selected class.
When Supplier is selected, the following fields are filtered:
Demand Group - Filtered to only display demand groups containing a SKU pack-size that is supplied by the selected supplier.
SKU - Filtered to only display SKUs having a pack-size supplied by the selected supplier.
Class - Filtered to only display classes containing a SKU that has a pack-size supplied by the selected supplier.
When Order Source is selected, the following field is filtered:
SKU - If the selected order source is a supplier, SKU is filtered to only display SKUs having a pack-size supplied by the supplier. If the selected order source is a warehouse, SKU is filtered to only display SKUs having a pack-size ranged to the warehouse.
Some fields need to filter a large amount of information. To help you select the information, there are two types of LOV buttons:
LOV buttons: Allow you to pick from a list of valid data that can be used in the field. The LOV button only allows you to make one selection.
Multi-select LOV buttons: For fields that permit multiple values, you can access a list of values window in multi-select view. The box contains two blocks. One block contains the predefined values that are available to you. The second block contains the values that have already been assigned to the field, if any. You have the option of:
Removing assigned values, which places them back in the available list.
Adding values, which places them in the selected list.
When a multi-select LOV button has multiple values selected, the first value that was selected is displayed followed by an ellipse.
The list of values window displays the first set of 20 values and a paging mechanism. To view additional sets of information, select from the list on the left side.
Perform the following steps to use the LOV button:
Click the LOV button next to a text field. The List of Values Window opens. The total number of values appears on the footer of the window.
Note: You can enter information into the field before you click the LOV button. A partial list of values is return that matches the information you entered. If you enter a complete, valid value and press Enter, the information is displayed without opening the list of values window. |
Select a value. Page as necessary to find your value.
Click Select. The field is automatically filled in with the selected value.
Perform the following steps to use the multi-select LOV button:
Click the multi-select LOV button next to a text field. The list of values window opens. The total number of values appears on the footer of the window.
Note: You can enter information into the field before you click the multi-select LOV button. A partial list of values is returned that matches the information you entered. If you enter a complete valid value and press Enter, the information is displayed without opening the list of values window. |
Select the appropriate values:
Select one or more values in the selected values box. Page as necessary to find your value.
Click the move right button. The values are displayed in the selected values box.
Note: To move all values displayed in the available area, click the move all right button. |
Remove unneeded values:
Click the move left button. The values are removed from the selected values box
Note: To move all values displayed in the selected area, click the move all left button. |
Click Select. The field is automatically filled in with the selected values.
For fields that permit multiple values, you can use a transfer box. The box contains two blocks. One block contains the predefined values that are available to you. The second block contains the values that have already been assigned to the field, if any. You have the option of:
Removing assigned values, which places them in the available list.
Perform the following steps to use a transfer box:
Select one or more values in the available values box.
Click the move right button. The values are moved to the selected values box.
Note: To move all displayed values, click the move all right button. |
Remove Unneeded Values:
Click the move left button. The values are returned to the available values list.
Note: To move all displayed values, click the move all left button. |
Perform the following steps to move top level folders and folder components:
Select the top level folder to move the folder and all components contained within the folder.
Select the individual component of the folder to move the folder component without including the entire folder.
In a table you can sort the results:
To sort the list, click any column heading. Hatch marks indicate the column that is currently sorted as well as the order: ascending or descending.
To reverse the current sort order, click the same column heading again.
To sort on multiple columns, where allowed, click the column heading to select the sort order and then right-click the column heading. The column heading turns red to indicate the column is locked. Repeat this process for other columns displayed on screen.
On some tabs, like the Alerts tab where numerous records may be displayed, paging controls appear at the bottom of the tab. This feature allows you to page through the records as needed. The total number of pages appears to the left of the paging controls.
Perform the following steps to use the paging controls:
To page forward, click Next. The next page of records appears.
To page backward, click Previous. The previous page of records appears.
To view the first page of records, click First Page. The first page of records appears.
To view the last page of records, click Last Page. The last page of records appears.
The following sections provide information about the online help for Oracle Retail Advanced Inventory Planning.
The online help system uses JavaScript for some of its functionality. Make sure you have enabled JavaScript for your Web browser. Refer to the online help in your Web browser for instructions on enabling JavaScript.
The help site provides step-by-step procedures as well as other information about using Oracle Retail Advanced Inventory Planning. We have implemented some tools to assist your navigation of the help site. The following sections explain these tools.
This section provides information about the documentation conventions used in the online help.
Note: Notes are displayed using this convention. Notes contain additional information about the process or procedure that you are performing. |
Navigate: The navigation sections of a procedure provide information about how to access the window that is the starting point of a procedure.
The table of contents is the most common way that you will navigate to your topic.
Select the Contents tab to display the table of contents on the left side of your screen.
Double-click a book to expand it and view the topics.
Select a topic from the table of contents to view it.
Use the search feature to explore the contents of your topics and find matches to queries that you define. There are some basic rules for making queries in full-text searches.
You can type your search in uppercase or lowercase characters. Searches are not case sensitive.
You can search for any combination of letters (a-z) and numbers (0-9).
Punctuation marks such as the period, colon, semicolon, comma, and hyphen are ignored during a search.
Group the elements of your search using double quotes or parentheses.
You cannot search for quotation marks.
Follow this procedure to use the search feature.
Select the Search tab to display the search feature on the left side of your screen.
In the Search field, enter the word or words that you want to find.
Press Enter. Topics that match your search criteria display in the left pane.
Select a topic to view it.
