| Tekelec Platform Operations, Administration, and Maintenance (OAM) Release 7.5 E88997 |
![]() Previous |
![]() Next |
Table 4-2 describes the elements of the Networks Insert form.
Table 4-2 Networks Insert Elements
| Field | Description | Data Input Notes |
| Network Name | The name of the network. | Must be unique. Format: String Range: 1-31 alphanumeric characters. Must start with a letter. No special characters are allowed. Defaut: n/a A value is required. |
| Network Type | The type of network in the context of the application. | Format: List Range: OAM or Signaling Default: OAM |
| VLAN ID | The VLAN ID of the Network | Format: Numeric Range: 1-4094 A value is required. |
| Network Address | The network address of the Network | Format: Valid network address Range: Dotted decimal (IPv4) or colon hex (IPv6) Default: n/a A value is required. |
| Netmask | Subnetting to apply to servers within the Network | Format: Valid network netmask Range: Prefix length (IPv4 or IPv6) or dotted quad decimal (IPv4) Default: n/a A value is required. |
| Router IP | The IP address of a router on this network. Note: If this is a default network, this i used as the gateway address of the default route on servers with interfaces on this network. If customer router monitoring is enabled, this address is the one monitored. |
Format: Valid IP address Range: Dotted decimal (IPv4) or colon hex (IPv6) Default: n/a Note: A value is not required. Networks without a router IP cannot be used as the default network. The default network selection defaults to No. |
| Default Network | Whether the network is the default gateway | Format: Option Range: Yes or No |
| Routed | Whether the network is routed outside its network element. Note: The network is automatically assigned to a network element when a server in a network element has an IP from the network assigned is to it. |
Note: Select No to allow the same IMI network/IPs to be used at multiple Signaling sites. |
