| Tekelec Platform Operations, Administration, and Maintenance (OAM) Release 7.5 E88997 |
![]() Previous |
![]() Next |
Table 3-15 describes the Range-Based Address Resolution (RBAR) Group Administration permissions.
Table 3-15 RBAR Configuration Permissions
| Permission | Description |
| Applications | Allows a user to create, view, and delete Applications |
| Exceptions | Allows a user to edit and view Exceptions |
| Destinations | Allows a user to create, edit, view and delete Destinations |
| Address Tables | Allows a user to create, view, and delete Address Tables |
| Addresses | Allows a user to create, edit, view, and delete Addresses |
| Address Resolutions | Allows a user to create, edit, view, and delete Address Resolutions |
| System Options | Allows a user to view and edit RBAR System Options |
