The following tables describe the CSV file content and attribute column positions for all configuration data supported by the Policy and Charging Application Type.
"PCRFs elements" in the PCA Help describes the configuration data elements listed in Table 5-80 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-80 PCRFs CSV Format
Column | Data Description |
0 | Application Type (Pca - Policy and Charging Application) |
1 | Pcrf (Keyword) |
2 | PCRF Peer Node Name (Key) |
3 | Comments |
"Binding Key Priority elements" in the PCA Help describes the configuration data elements listed in Table 5-81 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-81 Binding Key Priority CSV Format
1 | BindPriority (Keyword) |
2 | Priority 1 |
3 | Binding Key Type 1 (Imsi, Msisdn, Ipv4, Ipv6) |
4 | Priority 2 |
5 | Binding Key Type 2 (Imsi, Msisdn, Ipv4, Ipv6) |
6 | Priority 3 |
7 | Binding Key Type 3 (Imsi, Msisdn, Ipv4, Ipv6) |
8 | Priority 4 |
9 | Binding Key Type 4 (Imsi, Msisdn, Ipv4, Ipv6) |
"Site Options elements" and "Network-Wide Options elements" in the PCA Help describes the configuration data elements listed in Table 5-82 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-82 Policy DRA Options CSV Format
1 | PdraOptions (Keyword) |
2 | Enable Topology Hiding |
3 | Topology Hiding Scope |
4 | Default Topology Hiding FQDN |
5 | Default Topology Hiding Realm |
6 | Topology Hiding Host |
7 | Topology Hiding Realm |
8 | Peer Route Table Name |
9 | Enable PCRF Pooling |
10 | PCRF Pooling Mode |
11 | Default APN for Non Specific Binding Correlation |
12 | Early Binding Polling Interval |
13 | Maximum Early Binding Lifetime |
14 | Suspect Binding Removal Events Ignore Interval |
15 | Suspect Binding Removal Events Reset Interval |
16 | Suspect Binding Removal Events Threshold |
17 | RAR Origin Host and Realm Option |
18 | Max Query RAR Rate Per Session Server Group |
19 | RarAttemptedThreshold |
20 | Max Release RAR Rate Per Session Server Group |
21 | Max Attempts Per Release RAR |
22 | Query RAR Queue Capacity Per Session Server Group |
23 | Release RAR Queue Capacity Per Session Server Group |
"Error Codes elements" in the PCA Help describes the configuration data elements listed in Table 5-83 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-83 PCA Error Codes CSV Format
1 | ErrorCodes (Keyword) |
2 | Error Condition (Key) (PdraUnavailCong, PcaFuncUnavailableOrDisabled, BindingNotFound, UnableToRoute, SbrError, BindingKeyNotFoundCondition, SessionNotFound, MissingOrUnconfiguredApn) |
3 | Gx/Gxx Result Code |
4 | Gx/Gxx Vendor ID |
5 | Rx Result Code |
6 | Rx Vendor ID |
7 | S9 Result Code |
8 | S9 Vendor ID |
9 | Gx-Prime Result Code |
10 | Gx-Prime Vendor ID |
11 | Gy/Ro Result Code |
12 | Gy/Ro Vendor ID |
13 | All Result Code |
14 | All Vendor ID |
"PCA Access Point Names elements" in the PCA Help describes the configuration data elements listed in Table 5-84 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-84 PCA Access Point Names CSV Format
1 | AccessPointName (Keyword) |
2 | Access Point Name |
3 | Function Name |
4 | PCRF Pool Name |
5 | Maximum Allowed Sessions per IMSI |
6 | Per IMSI Session Exceeded Treatment (Reject, Route) |
7 | Stale Session Timeout |
8 | PCRF Sub-Pool Count (Read Only) |
9 | Last Updated Timestamp (Read Only) |
"Alarm Settings elements" in the PCA Help describes the configuration data elements listed in Table 5-85 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-85 Alarm Settings CSV Format
1 | AlarmSupp (Keyword) |
2 | Alarm Name 1 (PcaIngressMessageRate, OutstandingPdraSessionsThresholdExceeded) |
3 | Critical Alarm Threshold (Percent) 1 |
4 | Suppress Critical 1 (Yes, No) |
5 | Major Alarm Threshold (Percent) 1 |
6 | Suppress Major 1 (Yes, No) |
7 | Minor Alarm Threshold (Percent) 1 |
8 | Suppress Minor 1 (Yes, No) |
9 | Alarm Name 2 (PsbrActiveSessionsThreshold) |
10 | Critical Alarm Threshold (Percent) 2 |
11 | Suppress Critical 2 (Yes, No) |
12 | Major Alarm Threshold (Percent) 2 |
13 | Suppress Major 2 (Yes, No) |
14 | Minor Alarm Threshold (Percent) 1 |
15 | Suppress Minor 2 (Yes, No) |
16 | Alarm Name 3 (PsbrActiveBindingsThreshold) |
17 | Critical Alarm Threshold (Percent) 3 |
18 | Suppress Critical 3 (Yes, No) |
19 | Major Alarm Threshold (Percent) 3 |
20 | Suppress Major 3 (Yes, No) |
21 | Minor Alarm Threshold (Percent) 3 |
22 | Suppress Minor 3 (Yes, No) |
"Congestion Options elements" in the PCA Help describes the configuration data elements listed in Table 5-86 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-86 Congestion Options CSV Format
1 | CongOptions (Keyword) |
2 | Critical Alarm Onset Threshold 1 |
3 | Critical Alarm Abatement Threshold 1 |
4 | Major Alarm Onset Threshold 1 |
5 | Major Alarm Abatement Threshold 1 |
6 | Minor Alarm Onset Threshold 1 |
7 | Minor Alarm Abatement Threshold 1 |
8 | Congestion Level 1- Discard Session Creation Requests |
9 | Congestion Level 1- Discard Session Update Requests |
10 | Congestion Level 1- Discard Session Terminate Requests |
11 | Congestion Level 2- Discard Session Creation Requests |
12 | Congestion Level 2- Discard Session Update Requests |
13 | Congestion Level 2- Discard Session Terminate Requests |
14 | Congestion Level 3- Discard Session Creation Requests |
15 | Congestion Level 3- Discard Session Update Requests |
16 | Congestion Level 3- Discard Session Terminate Requests |
"PCRF Pools elements" in the PCA Help describes the PCRF Pools CSV Record elements listed in Table 5-87 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-87 PCRF Pools CSV Record Format
1 | PcrfPool (Keyword) |
2 | PCRF Pool Name (Key) |
3 | Is Pcrf SubPool |
4 | Comments |
"PCRF Sub-Pool Selection Rules elements" in the PCA Help describes the PCRF Sub-Pool Selection Rules CSV Record elements listed in Table 5-88 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-88 PCRF Sub-Pool Selection Rules CSV Record Format
1 | SubPoolSelRules (Keyword) |
2 | Rule Name (Key) |
3 | Priority |
5 | Condition Parameter (Origin-Host) |
6 | Condition Operator (Equals, StartsWith, EndsWith) |
7 | Condition Value |
8 | PCRF Sub-Pool Name |
"PCRF Pool To PRT Mapping CSV Record elements" in the PCA Help describes the PCRF Pool To PRT Mapping CSV Record elements listed in Table 5-89 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-89 PCRF Pool To PRT Mapping CSV Record Format
1 | PcrfPoolToPrt (Keyword) |
3 | Peer Route Table Name |
"General Options CSV Record elements" in the PCA Help describes the General Options CSV Record elements listed in Table 5-90 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-90 General Options CSV Record Format
1 | GeneralOptions (Keyword) |
2 | Policy DRA Enabled |
3 | Online Charging DRA Enabled |
4 | Number of Policy Binding Server Groups |
5 | Number of Policy and Charging Session Sever Groups |
6 | Default Stale Session Timeout |
7 | Maximum Audit Frequency |
"Online Charging DRA OCS Session State CSV Record elements" in the PCA Help describes the OCS Session State CSV Record elements listed in Table 5-91 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-91 Online Charging DRA OCS Session State CSV Record Format
1 | OcsSessionState (Keyword) |
2 | OCS Realm |
3 | OCS FQDN |
4 | OCS Session State Enabled |
"Online Charging DRA Realm CSV Record elements" in the PCA Help describes the OC-DRA Realm CSV Record elements listed in Table 5-92 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-92 Online Charging DRA Realm CSV Record Format
1 | Realm (Keyword) |
2 | OCS Realm |
3 | Comment |
"Online Charging DRA Network-Wide Options CSV Record elements" in the PCA Help describes the OC-DRA Network-Wide Options CSV Record elements listed in Table 5-93 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-93 Online Charging DRA Network-Wide Options CSV Record Format
1 | OcdraNwOptions (Keyword) |
2 | Session State Scope (None, All Messages, Specific Message) |
3 | Session State Unavailable Action (Send Answer, Route To Peer) |
4 | OCS Pool Selection Mode (Single Pool, Multiple Pools) |
"PCA Policy Clients Options CSV Record elements" in the PCA Help describes the OC-DRA Network-Wide Options CSV Record elements listed in Table 5-94 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-94 PDRA Policy Clients CSV Record Format
1 | PolicyClients (Keyword) |
2 | Policy Client Peer Node Name |
3 | Topology Hiding Enabled |
4 | Comments |
"Online Charging DRA OCSs CSV Record elements" in the PCA Help describes the OC-DRA OCSs CSV Record elements listed in Table 5-95 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-95 Online Charging DRA OCSs CSV Record Format
1 | Ocs (Keyword) |
2 | OCS Peer Node Names |
3 | Comments |
"Online Charging DRA CTFs CSV Record elements" in the PCA Help describes the OC-DRA CTFs CSV Record elements listed in Table 5-96 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-96 Online Charging DRA CTFs CSV Record Format
1 | Ctf (Keyword) |
2 | CTF Peer Node Names |
3 | Comments |
"Suspect Binding Removal Rules Elements" in the PCA Help describes the Suspect Binding Removal Rules CSV elements listed in Table 5-97 and configuration considerations for the data elements that must be observed when the elements are edited in the CSV files.
Table 5-97 Suspect Binding Removal Rules CSV Record Format
1 | SuspectBindingRemovalRules (Keyword) |
3 | Application Name |
4 | Command Code |
5 | Error Scenario Category |
6 | Result Code |
7 | Vendor ID |
8 | Remove Suspect Binding Immediately |
9 | Comments |
