Table 10-21 describes the fields on the S9 PCRF Topology Hiding Configuration Sets View, Edit, and Insert pages. Data Input Notes apply only to the Insert and Edit pages; the View page is read-only.
Table 10-21 S9 PCRF Topology Hiding Configuration Sets Elements
| Field (* indicates required field) | Description | Data Input Notes |
| * S9 PCRF Topology Hiding Configuration Set Name | A name that uniquely identifies the S9 PCRF Topology Hiding Configuration Set. | Format: case-sensitive string; alphanumeric and underscore (_); must contain at least one alpha and cannot start with a digit Range: 1 - 32 characters |
| Pseudo Hostname Generation | Attributes to control the format and generation of Pseudo Hostnames corresponding to an Actual Hostname.
Count:
Randomize Count:
Auto Generate:
Prefix:
Suffix:
Length:
| * Hostnames | List of Actual Hostnames and their Pseudo Hostnames in this S9 PCRF Topology Hiding Configuration Set. | Format: case-insensitive string consisting of a list of labels separated by dots, where a label may contain letters, digits, dashes (-), and underscore (_). A label must start with a letter, digit, or underscore and must end with a letter or digit. Underscores can be used only as the first character. Label - up to 63 characters; S9 PCRF Pseudo Hostname - up to 255 characters. |
| S9 PCRF Actual Hostname Not Found Action | Action to be performed when the Orig-Host in the Diameter message is not configured as Actual Hostname in this S9 PCRF Topology Hiding Configuration Set. | Default: Send Answer Range: n/a |
| S9 PCRF Actual Hostname Not Found Answer Result-Code Value | Value to be placed in the Result-Code AVP of the Answer message. S9 PCRF Actual Hostname Not Found Answer Result-Code Value is required if action is Send Answer. | Default: 3002 Range: 1000 - 5999 |
| S9 PCRF Actual Hostname Not Found Vendor ID | Vendor ID is placed in Vendor ID AVP | Default: n/a Range: 1 - 4294967295 |
| S9 PCRF Actual Hostname Not Found Answer Error Message | String to be placed in the Error-Message AVP of the Answer message | Default: null string, no Error-Message AVP in Answer message Range: 0 - 64 characters |
