This chapter includes the following sections:
MAF AMX is a subframework within Mobile Application Framework (MAF) that provides a set of UI components that enable you to create an application feature whose behavior is identical on all supported platforms. MAF AMX allows you to use UI components declaratively by dragging them onto a page editor. A typical MAF AMX application feature includes several interconnected pages that can be navigated through various paths.
When developing interfaces for mobile devices, always be aware of the fact that the screen space is very limited. In addition, touchscreen support is not available on some mobile devices.
For more information, see the following:
When using the MAF Feature editor to create objects as part of an application, OEPE creates an ID for the object that cannot be changed later.
Task flows allow you to define the navigation between MAF AMX pages. Using your application workspace in OEPE (see Creating a MAF Application), you can start creating the user interface for your MAF AMX application feature by designing task flows. MAF AMX uses navigation cases and rules to define the task flow. These definitions are stored in a file with the default name of task-flow-definition.xml
(see What You May Need to Know About the task-flow-definition.xml File).
A MAF sample application called Navigation (select File > New > MAF Examples, then select Navigation) demonstrates how to use various navigation techniques, such as circular navigation, routers, and so on.
MAF enables you to create MAF AMX application features that have both bounded and unbounded task flows. As described in What You May Need to Know About Bounded and Unbounded Task Flows, a bounded task flow is also known as a task flow definition and represents the reusable portion of an application. In MAF, bounded task flows have a single entry point and no exit points. They have their own collections of activities and control-flow rules, as well as their own memory scope and managed-bean life span. Other characteristics of bounded task flows include accepting input parameters (see Passing Parameters to a Bounded Task Flow) and generating return values (see Configuring a Return Value from a Bounded Task Flow).
You use the MAF AMX Task Flow Designer to create bounded task flows for your application feature. This tool includes a diagrammer (see What You May Need to Know About the MAF Task Flow Diagrammer) in which you build the task flow by dragging and dropping activities and control flows (see What You May Need to Know About Task Flow Activities and Control Flows) from the Palette. You then define these activities and the transitions between them using the Properties window.
Unless a task flow has already been created, MAF automatically generates a default unbounded task flow (adfc-mobile-config.xml
file) when a new MAF AMX page is created.
A task flow is composed of the task flow itself and a number of activities with control flow rules between those activities (see What You May Need to Know About Task Flow Activities and Control Flows). Typically, the majority of the activities are view activities which represent different pages in the flow. When a method or operation needs to be called (for example, before a page is rendered), you use a method call activity with a control flow case from that activity to the appropriate next activity. When you want to call another task flow, you use a task flow call activity. If the flow requires branching, you use a router activity. At the end of a bounded task flow, you use a return activity which allows the flow to exit and control is sent back to the flow that called this bounded task flow.
You can use the Palette to declaratively create a bounded task flow for your MAF AMX application feature by dragging and placing task flow elements in the flow structure. When you place these elements in relation to one another, OEPE creates the XML metadata needed for navigation to work in your MAF AMX application feature in the task-flow-definition.xml
file (default). You can also edit the task flow definition file's source.
Before you begin
To design a task flow, the MAF application must include a View Controller project file (see Getting Started with MAF Application Development).
To create a task flow in OEPE, create a bounded task flow from the MAF Features Editor. For more information, see Defining the Application Feature Content as Remote URL or Local HTML.
Figure 11-1 Creating the Task Flow File from the MAF Features editor
Additionally, you can manually add elements to the task flow file by directly editing the page in the Source editor. To open the file in the Source editor, click the Source tab.
When manually editing the task flow file, keep in mind that all the document file names referring to MAF AMX pages, Java Script files, and CSS files are case-sensitive.
If special characters (such as an underscore, for example) are used in a file name, you should consult the mobile device specification to verify whether or not the usage of this character is supported.
Once the navigation for your MAF AMX application feature is defined, you can create the pages and add the components that will execute the navigation. For more information about using navigation components on a page, see How to Define Control Flows.
After you define the task flow for the MAF AMX application feature, you can double-click a view file to access the MAF AMX view. For more information, see Creating Views.
A task flow consists of activities and control flow cases that define the transitions between activities.
The MAF Task Flow designer supports activities listed in Table 11-1.
Table 11-1 Task Flow Activities
Activity | Description |
View |
Displays an MAF AMX page. For more information, see Adding View Activities. |
Method Call |
Invokes a method (typically a method on a managed bean). You can place a method call activity anywhere in the control flow of an MAF AMX application feature to invoke logic based on control flow rules. For additional information, see Adding Method Call Activities. You can also specify parameters that you pass into a method call that is included in a task flow. These include standard parameters for a method call action in an MAF AMX task flow. When you use the designer to generate a method, it adds the required arguments and type. At runtime, you can define parameters for a method call in a task flow and pass parameters into the method call itself for its usage. For more information, see How to Add and Use Task Flow Activities |
Router |
Evaluates an Expression Language (EL) expression and returns an outcome based on the value of the expression. These outcomes can then be used to route control to other activities in the task flow. For more information, see Adding Router Activities. |
Task Flow Call |
Calls a bounded task flow from either an unbounded or bounded task flow. While a task flow call activity allows you to call a bounded task flow located within the same MAF AMX application feature, you can also call a bounded task flow from a different MAF AMX application feature or from a Feature Archive file (FAR) that has been added to a library. The task flow call activity supports task flow input parameters and return values. For more information, see Adding Task Flow Call Activities. |
Task Flow Return |
Identifies the point in an application's control flow where a bounded task flow completes and sends control flow back to the caller. You can use a task flow return only within a bounded task flow. For more information, see Adding Task Flow Return Activities. |
The MAF Task Flow designer supports control flows listed in Table 11-2.
Table 11-2 Control Flows
Control Flow | Description |
Control Flow Case |
Identifies how control passes from one activity to the next in the MAF AMX application feature. For more information, see Defining a Control Flow Case. |
Wildcard Control Flow Rule |
Represents a control flow case that can originate from any activities whose IDs match a wildcard expression.For more information, see Adding a Wildcard Control Flow Rule. |
The task-flow-definition.xml
file enables you to design the interactions between views (MAF AMX pages) by dragging and dropping task flow components from the Palette onto the diagrammer.
Figure 11-2 shows a sample task flow file called task-flow-definition.xml
. In this file, the control flow is directed from Call1
to Call2
by the task flow call CallFlow
. (See What You May Need to Know About MAF Support for Back Navigation).
Figure 11-2 Task Flow File
As illustrated in Figure 11-2, the task flow diagram and Palette display automatically after you create a task flow using the MAF Task Flow Creation utility. The task flow diagram is a visual editor onto which you can drag and drop activities and task flows from the Palette. You can also edit the task flow file directly, by clicking the Source tab shown in Figure 11-2. For more information, see How to Add and Use Task Flow Activities.
You use the task flow diagrammer, selecting options from the Palette, to drag and drop activities, views, and control flows.
To add an activity to an MAF task flow:
) to display the task flow diagram and the Palette. The diagrammer displays the task flow editor. The Palette automatically displays the components available for an MAF task flow.Note:
There is a default activity that is associated with each bounded task flow.
One of the primary types of task flow activity is the view activity which displays an MAF AMX page.
XML metadata in the source file of the task flow associates a view activity with a physical MAF AMX page. An id
attribute identifies the view activity.
You can configure view activities in your task flow to pass control to each other at runtime. For example, to pass control from one view activity (view activity A) to a second view activity (view activity B), you could configure a command component, such as a Button or a Link on the page associated with view activity A. To do so, you set the command component's Action attribute to the control flow case from-outcome
that corresponds to the task flow activity that you want to invoke (for example, view activity B). At runtime, the end user initiates the control flow case by invoking the command component. It is possible to navigate from a view activity to another activity using either a constant or dynamic value on the Action attribute of the UI component:
A constant value of the component's Action attribute is an action outcome that always triggers the same control flow case. When an end user clicks the component, the activity specified in the control flow case is performed. There are no alternative control flows.
A dynamic value of the component's Action attribute is bound to a managed bean or a method. The value returned by the method binding determines the next control flow case to invoke. For example, a method might verify user input on a page and return one value if the input is valid and another value if the input is invalid. Each of these different action values trigger different navigation cases, causing the application to navigate to one of two possible target pages.
For more information, see How to Specify Action Outcomes Using UI Components.
You can also write an EL expression that must evaluate to true
before control passes to the target view activity. You write the EL expression as a value for the <if>
child element of the control flow case in the task flow.
The examples below demonstrate what happens when you pass control between View activities:
This example shows a control flow case defined in the XML source file for a bounded or unbounded task flow.
<control-flow-rule> <from-activity-id>Start</from-activity-id> <control-flow-case> <from-outcome>toOffices</from-outcome> <to-activity-id>WesternOffices</to-activity-id> </control-flow-case> </control-flow-rule>
As the example below shows, a Button on an MAF AMX page associated with the Start view activity specifies toOffices
as the action
attribute. When the end user clicks the button, control flow passes to the WesternOffices
activity specified as the to-activity-id
in the control flow metadata.
<amx:commandButton text="Go" id="b1" action="toOffices">
As previously stated, the view activity is associated in metadata with an actual MAF AMX page which it displays when added to a task flow. You add a view activity by dragging and dropping it from the Palette. You can create an actual MAF AMX page by right-clicking the View activity in the Diagram window and then define characteristics for the page through the displayed dialog (see Figure 11-15).
If you are creating a bounded task flow, you may want to designate a specific activity as the default activity (see What You May Need to Know About Bounded and Unbounded Task Flows). This allows the specific activity to execute first whenever the bounded task flow runs. By default, OEPE makes the first activity you add to the task flow the default. To change to a different activity, right-click the appropriate activity in the Diagram window and choose Create Page Definition (see Figure 11-3).
Figure 11-3 Defining Default Activity
You use a router activity to route control to activities based on the runtime evaluation of EL expressions.
Each control flow corresponds to a different router case. Each router case uses the following elements to choose the activity to which control is next routed:
expression
: an EL expression that evaluates to true
or false
at runtime.
The router activity returns the outcome that corresponds to the EL expression that returns true
outcome
: a value returned by the router activity if the EL expression evaluates to true
If the router case outcome
matches a from-outcome
on a control flow case, control passes to the activity that the control flow case points to. If none of the cases for the router activity evaluate to true
, or if no router activity cases are specified, the outcome
specified in the router Default Outcome field (if any) is used.
Consider using a router activity if your routing condition can be expressed in an EL expression: the router activity allows you to show more information about the condition on the task flow.
When you drag a Router activity onto the diagram, you can use the Properties window to create an expression whose evaluation determines which control flow rule to follow. Using the Properties window, you configure the Activity ID and Default Outcome properties of the router activity and add router cases to the router activity.
When defining the Activity ID attribute, write a value that identifies the router activity in the task flow's source file.
When defining the Default Outcome attribute, specify an activity that the router activity passes control to if no control flow cases evaluate to true or if no control flow case is specified.
For each router case that you add, specify values by clicking Add ( + ) in the Control Flow Cases section, as shown in Figure 11-4.
Figure 11-4 Configuring Router Activity
Expression: An EL expression that evaluates to true
or false
at runtime.
For example, to reference the value in an input text field of a view activity, write an EL expression similar to the following:
#{pageFlowScope.value=='view2'}
If this EL expression returns true
, the router activity invokes the outcome that you specify in the Outcome field.
Outcome: The outcome the router activity invokes if the EL expression specified by Expression returns true
Create a control flow case or a wildcard control flow rule for each outcome in the diagram of your task flow. For example, for each outcome in a control flow case, ensure that there is a corresponding from-outcome
When you configure the control flow using a router activity, OEPE writes values to the source file of the task flow based on the values that you specify for the properties of the router activity.
When you drag a Method Call activity onto the diagram, you can use the New Object dialog to choose the method to call.
Use a method call activity to call a custom or built-in method that invokes the MAF AMX application feature logic from anywhere within the application feature's control flow. You can specify methods to perform tasks such as initialization before displaying a page, cleanup after exiting a page, exception handling, and so on.
You can set an outcome for the method that specifies a control flow case to pass control to after the method finishes. You can specify the outcome as one of the following:
fixed-outcome
: upon successful completion, the method always returns this single outcome, for example, success
. If the method does not complete successfully, an outcome is not returned. If the method type is void, you must specify a fixed-outcome
and cannot specify to-string
You define this outcome by setting the Fixed Outcome field in the Properties window.
to-string
: if specified as true
, the outcome is based on calling the toString
method on the Java object returned by the method. For example, if the toString
method returns editBasicInfo
, navigation goes to a control flow case named editBasicInfo
You define this outcome by setting the toString() field in the Properties window.
You can associate the method call activity with an existing method by dropping a data control operation from the Data Controls window directly onto the method call activity in the task flow diagram. You can also drag methods and operations directly to the task flow diagram: a new method call activity is created automatically when you do so. You can specify an EL expression and other options for the method.
You configure the method call by modifying its activity identifier in the Activity ID field if you want to change the default value. If you enter a new value, the new value appears under the method call activity in the diagram.
In the Method field, enter an EL expression that identifies the method to call. Note that the bindings variable in the EL expression references a binding from the current binding container. In order to specify the bindings variable, you must specify a binding container definition or page definition. For more information, see What You May Need to Know About Generated Drag and Drop Artifacts.
You can also use the Expression Builder to build the EL expression for the method:
Choose Method Expression Builder from the Property Editor for the Method field.
In the Expression Builder dialog, navigate to the method that you want to invoke and select it.
If the method call activity is to invoke a managed bean method, double-click the method call activity in the diagram. This invokes a dialog where you can specify the managed bean method you want to invoke.
You can specify parameters and return values for a method by using the Parameters section of the Properties window. If parameters have not already been created by associating the method call activity to an existing method, add the parameters by clicking Add ( + ) and setting the following:
Class: enter the parameter class. For example, java.lang.Double
Value: enter an EL expression that retrieves the value of the parameter. For example:
#{pageFlowScope.shoppingCart.totalPurchasePrice}
Return Value: enter an EL expression that identifies where to store the method return value. For example:
#{pageFlowScope.Return}
You can use a task flow call activity to call a bounded task flow from either the unbounded task flow (see Unbounded Task Flows) or a bounded task flow (see Bounded Task Flows). This activity allows you to call a bounded task flow located within the same or a different MAF AMX application feature.
The called bounded task flow executes its default activity first. There is no limit to the number of bounded task flows that can be called. For example, a called bounded task flow can call another bounded task flow, which can call another, and so on resulting in the creation of chained task flows where each task flow is a link in a chain of tasks.
To pass parameters into a bounded task flow, you must specify input parameter values on the task flow call activity. These values must correspond to the input parameter definitions on the called bounded task flow. For more information, see Specifying Input Parameters on a Task Flow Call Activity.
The value on the task flow call activity input parameter specifies the location within the calling task flow from which the value is to be retrieved.
The value on the input parameter definition for the called task flow specifies where the value is to be stored within the called bounded task flow once it is passed.
When a bounded task flow is associated with a task flow call activity, input parameters are automatically inserted on the task flow call activity based on the input parameter definitions set on the bounded task flow. Therefore, you only need to assign values to the task flow call activity input parameters.
By default, all objects are passed by reference. Primitive types (for example, int
, long
, or boolean
) are always passed by value.
The technique for passing return values out of the bounded task flow to the caller is similar to the way that input parameters are passed. For more information, see Configuring a Return Value from a Bounded Task Flow.
To use a task flow call activity:
Add a task flow call activity to the calling bounded or unbounded task flow to call a bounded task flow.
To call a bounded task flow:
Open a bounded task flow file in the Diagram view.
From the Activities pane of the Palette, drag and drop a Task Flow Call activity onto the diagram.
Choose one of the following options to identify the called task flow:
Double-click the newly-dropped task flow call activity to open the Create MAF Task Flow dialog where you define settings for a new bounded task flow.
Drag an existing bounded task flow from the Project Explorer and drop it on the task flow call activity.
If you know the name of the bounded task flow that you want to invoke, perform the following steps:
In the Diagram view, select the Task Flow Call activity.
In the Properties window, expand the General section, and select Static from the Task Flow Reference list.
In the Document field, enter the name of the source file for the bounded task flow to call.
In the ID field, enter the bounded task flow ID contained in the XML source file for the called bounded task flow (see Figure 11-5).
Figure 11-5 Task Flow Call Activity That Invokes a Bounded Task Flow
If you do not know the name of the bounded task flow to invoke and it is dependent on an end user selection at runtime, perform the following steps:
In the Properties window, expand the General section, and select Dynamic from the Task Flow Reference list.
Use the Expression Builder to set the value of the Dynamic Task Flow Reference property field: write an EL expression that identifies the ID of the bounded task flow to invoke at runtime.
The suggested method for mapping parameters between a task flow call activity and its called bounded task flow is to first specify input parameter definitions for the called bounded task flow. Then you can drag the bounded task flow from the Project Explorer and drop it on the task flow call activity. The task flow call activity input parameters are created automatically based on the bounded task flow's input parameter definition. For more information, see Passing Parameters to a Bounded Task Flow.
You can, of course, first specify input parameters on the task flow call activity. Even if you have defined them first, they will automatically be replaced based on the input parameter definitions of the called bounded task flow, once it is associated with the task flow call activity.
If you have not yet created the called bounded task flow, you may still find it useful to specify input parameters on the task flow call activity. Doing so at this point allows you to identify any input parameters you expect the task flow call activity to eventually map when calling a bounded task flow.
To specify input parameters:
A task flow return activity identifies the point in an MAF AMX application feature's control flow where a bounded task flow completes and sends control flow back to the caller. You can use a task flow return activity only within a bounded task flow.
A gray circle around a task flow return activity icon indicates that the activity is an exit point for a bounded task flow. A bounded task flow can have zero or more task flow return activities.
Each task flow return activity specifies an outcome
that it returns to the calling task flow.
The outcome
returned to an invoking task flow depends on the end user action. You can configure control flow cases in the invoking task flow to determine the next action by the invoking task flow. Set the From Outcome property of a control flow case to the value returned by the task flow return activity's outcome
to invoke an action based on that outcome. This determines control flow upon return from the called task flow.
To add a task flow return activity:
Page definition files define the binding objects that populate data at runtime. They are typically used in an MAF AMX application feature to bind page UI components to data controls. The following task flow activities can also use page definition files to bind to data controls:
Method call: You can drag and drop a data control operation from the Data Controls window onto a task flow to create a method call activity or onto an existing method call activity. In both cases, the method call activity binds to the data control operation.
Router: associating a page definition file with a router activity creates a binding container. At runtime, this binding container makes sure that the router activity references the correct binding values when it evaluates the router activity cases' EL expressions. Each router activity case specifies an outcome to return if its EL expression evaluates to true
. For this reason, only add data control operations to the page definition file that evaluate to true
or false
Task flow call: associating a page definition file with a task flow call activity creates a binding container. At runtime, the binding container is in context when the task flow call activity passes input parameters. The binding container makes sure that the task flow call activity references the correct values if it references binding values when passing input parameters from a calling task flow to a called task flow.
View: you cannot directly associate a view activity with a page definition file. Instead, you associate the page that the view activity references.
If you right-click any of the preceding task flow activities, except view activity, in the Diagram window for a task flow, OEPE displays an option on the context menu that enables you to create a page definition file if one does not yet exist. If a page definition file does exist, OEPE displays a context menu option for all task flow activities to go to the page definition file (see Accessing the Page Definition File). OEPE also displays the Edit Binding context menu option when you right-click a method call activity that is associated with a page definition file.
A task flow activity that is associated with a page definition file displays an icon in the lower-right section of the task flow activity icon.
To associate a page definition file with a task flow activity:
For more information about page definition files, see What You May Need to Know About Generated Drag and Drop Artifacts.
When the preceding steps are completed, OEPE generates a page definition file for the task flow activity at design time. The file name of the page definition file comprises the originating task flow and either the name of the task flow activity or the data control operation to invoke. OEPE also generates an EL expression from the task flow activity to the binding in the created page definition file. At runtime, a binding container ensures that a task flow activity's EL expressions reference the correct value.
You use the following task flow components to define the control flow in your MAF AMX application feature:
Control Flow Case (see Defining a Control Flow Case)
Wildcard Control Flow Rule (see Adding a Wildcard Control Flow Rule)
You can create navigation using the Control Flow Case component, which identifies how control passes from one activity to the next. To create a control flow, select Control Flow Case from the Palette. Next, connect the Control Flow Case to the source activity, and then to the destination activity. OEPE creates the following after you connect a source and target activity:
control-flow-rule
: Identifies the source activity using a from-activity-id
control-flow-case
: Identifies the destination activity using a to-activity-id
To define a control flow case directly in the MAF task flow diagram:
from-outcome
contains a value that can be matched against values specified in the action attribute of the MAF AMX UI components.from-outcome
, select the text next to the control flow in the diagram. By default, this is a wildcard character.from-activity-id
(the identifier of the source activity), or the to-activity-id
(the identifier for the destination activity), drag either end of the arrow in the diagram to a new activity.MAF task flows support the wildcard control flow rule, which represents a control flow from-activity-id
that contains a trailing wildcard (foo*
) or a single wildcard character. You can add a wildcard control flow rule to an unbounded or bounded task flow by dragging and dropping it from the Palette. To configure your wildcard control flow rule, use the Properties window.
To add a wildcard control flow rule:
The example below shows the general syntax of a control flow rule element in the task flow source file.
<control-flow-rule> <from-activity-id>from-view-activity</from-activity-id> <control-flow-case> <from-action>actionmethod</from-action> <from-outcome>outcome</from-outcome> <to-activity-id>destinationActivity</to-activity-id> <if>#{myBean.someCondition}</if> </control-flow-case> <control-flow-case> ... </control_flow-case> </control-flow-rule>
Control flow rules can consist of the following metadata:
control-flow-rule
: a mandatory wrapper element for control flow case elements.
from-activity-id
: the identifier of the activity where the control flow rule originates (for example, source
A trailing wildcard ( * ) character in from-activity-id
is supported. The rule applies to all activities that match the wildcard pattern. For example, login*
matches any logical activity ID name beginning with the literal login
. If you specify a single wildcard character in the metadata (not a trailing wildcard), the control flow automatically converts to a wildcard control flow rule activity in the diagram. For more information, see Adding a Wildcard Control Flow Rule.
control-flow-case
: a mandatory wrapper element for each case in the control flow rule. Each case defines a different control flow for the same source activity. A control flow rule must have at least one control flow case.
from-action
: an optional element that limits the application of the rule to outcomes from the specified action method. The action method is specified as an EL binding expression, such as, for example, #{backing_bean.cancelButton_action}
In the example above, control passes to destinationActivity
only if outcome is returned from actionmethod
The value in from-action
applies only to a control flow originating from a view activity, not from any other activity types. Wildcards are not supported in from-action
from-outcome
: identifies a control flow case that will be followed based on a specific originating activity outcome. All possible originating activity outcomes should be accommodated with control flow cases.
If you leave both the from-action
and the from-outcome
elements empty, the case applies to all outcomes not identified in any other control flow cases defined for the activity, thus creating a default case for the activity. Wildcards are not supported in from-outcome
to-activity-id
: a mandatory element that contains the complete identifier of the activity to which the navigation is routed if the control flow case is performed. Each control flow case can specify a different to-activity-id
if
: an optional element that accepts an EL expression as a value. If the EL expression evaluates to true
at runtime, control flow passes to the activity identified by the to-activity-id
element.
At runtime, task flows evaluate control flow rules from the most specific to the least specific match to determine the next transition between activities. Evaluation is based on the following priority:
from-activity-id
, from-action
, from-outcome
: first, searches for a match in all three elements is performed.
from-activity-id
, from-outcome
: the search is performed in these elements if no match in all three elements is found.
from-activity-id
: if search in the preceding combinations did not result in a match, search is performed in this element only.
In the task flow example that Figure 11-6 shows, it is possible to take two separate paths to reach viewD based on the action outcome value (see How to Specify Action Outcomes Using UI Components): either from viewA to viewB to viewD, or from viewA to viewC to viewD.
Figure 11-6 Task Flow with Back Navigation
While you could theoretically keep track of which navigation paths had been followed and then directly implement the __back
navigation flow, it would be tedious and error-prone, especially considering the fact that due to the limited screen space on mobile devices transitions out of the navigation sequences occur very frequently. MAF provides support for a built-in __back
navigation that enables moving back through optional paths across a task flow: by applying its “knowledge" of the path taken, MAF performs the navigation back through the same path. For example, if the initial navigation occurred from viewA to viewC to viewD, on exercising the __back
option on ViewD MAF would automatically take the end user back to ViewA through ViewC rather than through ViewB.
For additional information, see the following:
You can enable navigation from one MAF AMX page to another through the use of the Navigation Drag Behavior operation. For more information, see How to Enable Drag Navigation.
Using the Properties window, you can specify an action outcome by setting the action
attribute of one of the following UI components to the corresponding control flow case from-outcome
leading to the next task flow activity:
Command Button (see How to Use Buttons)
Command Link (see How to Use Links)
List Item
You use the UI component's Action field to make a selection from a list of possible action outcomes defined in one or more task flow for a specific MAF AMX page.
A Back action (__back
) is automatically added to every list to enable navigation to the previously visited page.
An MAF AMX page can be referenced in both bounded and unbounded task flows, in which case actions outcomes from both task flows are included in the Action selection list.
You can create and use managed beans in your MAF application to store additional data or execute custom code. You can use usual editing mechanism to reference managed beans and create references to them for applicable fields. For more information, see Creating and Using Managed Beans.
Click on the name of the task flow (not the icon) to invoke the Edit Property dialog that Figure 11-7 shows.
Figure 11-7 Edit Property Dialog for Action
Table 11-5 lists MAF AMX attributes for which the Edit option in the Properties window is available.
Table 11-3 Editable Attributes
Property | Element |
Clicking Edit for all other properties invokes a similar dialog, but without the Action Outcome option
The preceding dialogs demonstrate that you can either create a managed bean, or select an available action outcome for the action property.
The Action Outcome list shown in Figure 11-7 contains the action outcomes from all task flows to which a specific MAF AMX page belongs. In addition, this list contains a __back
navigation outcome to go back to the previously visited page (see How to Specify Action Outcomes Using UI Components for more information). If a page is not part of any task flow, the only available outcome in the Action Outcome list is __back
. When you select one of the available action outcomes and click OK, the action property value is updated with the appropriate EL expression, such as the following for a commandButton
<amx:commandButton action="goHome"/>
The Method Binding option (see Figure 11-7) allows you to either create a new managed bean class or select an existing one.
To create a new managed bean class:
By defining the page transition style on the task flow, you can specify how MAF AMX pages transition from one view to another. The behavior of your MAF AMX page at transition can be as follows:
fading in
sliding in from left
sliding in from right
sliding up from bottom
sliding down from top
sliding in from start
sliding in from end
flipping up from bottom
flipping down from top
flipping from left
flipping from right
flipping from start
flipping from end
none
Sliding in from start and end, as well as flipping from start and end are used on the iOS platform to accommodate the right-to-left text direction. It is generally recommended to use the start and end transition style as opposed to left and right.
You cannot enable flipping on the Android platform.
You set the transition style by modifying the transition
attribute of the control-flow-case
(Control Flow Case component), as this example shows.
<control-flow-rule id="__1"> <from-activity-id>products</from-activity-id> <control-flow-case id="__2"> <from-outcome>details</from-outcome> <to-activity-id>productdetails</to-activity-id> <transition>fade</transition> </control-flow-case> </control-flow-rule>
In the Properties window, the transition
attribute is located under Behavior. The default transition style is slideLeft
Tip:
When defining the task flow, you should specify the control-flow-case
's transition
value such that it is logical. For example, if the transition occurs from left to right with the purpose of navigating back, then the transition should return to the previous page by sliding right.
Task flows provide a modular approach for defining control flow in an MAF AMX application feature. Instead of representing an application feature as a single large page flow, you can divide it into a collection of reusable task flows. Each task flow contains a portion of the application feature's navigational graph. The nodes in the task flows represent activities. An activity node represents a simple logical operation such as displaying a page, executing application logic, or calling another task flow. The transitions between the activities are called control flow cases.
There are two types of task flows in MAF AMX:
Unbounded Task Flows: a set of activities, control flow rules, and managed beans that interact to allow the end user to complete a task. The unbounded task flow consists of all activities and control flows in an MAF AMX application feature that are not included within a bounded task flow.
Bounded Task Flows: a specialized form of task flow that, in contrast to the unbounded task flow, has a single entry point and no exit points. It contains its own collections of activities and control-flow rules, as well as their own memory scope and managed-bean life span.
For a description of the activity types that you can add to unbounded or bounded task flows, see What You May Need to Know About Task Flow Activities and Control Flows.
A typical MAF AMX application feature contains a combination of one unbounded task flow created at the time when the application feature is created and one or more bounded task flows. At runtime, the MAF application can call bounded task flows from activities that you added to the unbounded task flow.
An MAF AMX application feature always contains one unbounded task flow, which provides one or more entry points to that application feature. An entry point is represented by a view activity. By default, the source file for the unbounded task flow is the adfc-mobile-config.xml
file.
Although it is possible create additional source files for unbounded task flows, the MAF AMX application feature combines all source files at runtime into the adfc-mobile-config.xml
file.
Figure 11-10 displays the diagram for an unbounded task flow from an MAF AMX application feature. This task flow contains a number of view activities that are all entry points to the application feature.
Figure 11-10 Unbounded Mobile Task Flow Diagram
Consider using an unbounded task flow if the following applies:
There is no need for the task flow to be called by another task flow.
The MAF AMX application feature has multiple points of entry.
There is no need for a specifically designated activity to run first in the task flow (default activity).
An unbounded task flow can call a bounded task flow, but cannot be called by another task flow.
By default, the IDE proposes a file name for the source file of a bounded task flow (see How to Create a Task Flow). You can modify this file name to reflect the purpose of the task to be performed.
A bounded task flow can call another bounded task flow, which can call another, and so on. There is no limit to the depth of the calls.
Figure 11-11 displays the diagram for a bounded task flow from an MAF AMX application feature.
Figure 11-11 Bounded Mobile Task Flow Diagram
The following are reasons for creating a bounded task flow:
The bounded task flow always specifies a default activity, which is a single point of entry that must execute immediately upon entry of the bounded task flow.
It is reusable within the same or other MAF AMX application features.
Any managed beans you use within a bounded task flow can be specified in a page flow scope, making them isolated from the rest of the MAF AMX application feature. These managed beans (with page flow scope) are automatically released when the task flow completes.
The following is a summary of the main characteristics of a bounded task flow:
Well-defined boundary: a bounded task flow consists of its own set of private control flow rules, activities, and managed beans. A caller requires no internal knowledge of page names, method calls, child bounded task flows, managed beans, and control flow rules within the bounded task flow boundary. Data controls can be shared between task flows.
Single point of entry: a bounded task flow has a single point of entry—a default activity that executes before all other activities in the task flow.
Page flow memory scope: you can specify page flow scope as the memory scope for passing data between activities within the bounded task flow. Page flow scope defines a unique storage area for each instance of a bounded task flow. Its lifespan is the bounded task flow, which is longer than request scope and shorter than session scope.
Addressable: you can access a bounded task flow by specifying its unique identifier within the XML source file for the bounded task flow and the file name of the XML source file.
Reusable: you can identify an entire group of activities as a single entity, a bounded task flow, and reuse the bounded task flow in another MAF AMX application feature within an MAF application.
You can also reuse an existing bounded task flow by calling it.
In addition, you can use task flow templates to capture common behaviors for reuse across different bounded task flows.
Parameters and return values: a caller can pass input parameters to a bounded task flow and accept return values from it (see Passing Parameters to a Bounded Task Flow and Configuring a Return Value from a Bounded Task Flow).
In addition, you can share data controls between bounded task flows.
On-demand loading of metadata: bounded task flow metadata is loaded on demand when entering a bounded task flow.
A task flow´s ability to accept input parameters and return parameter values allows you to manipulate data in task flows and share data between task flows. Using these abilities, you can optimize the reuse of task flows in your MAF AMX application feature.
Figure 11-12 shows a task flow that specifies an input parameter definition to hold information about a user in a pageFlow scope.
Figure 11-12 Input Parameters in Task Flow
You can specify parameter values using standard EL expressions if you call a bounded task flow using a task flow call activity. For example, you can specify parameters using the following syntax for EL expressions:
#{bindings.bindingId.inputValue}
#{CustomerBean.zipCode}
Appending inputValue
to the EL expression ensures that you assign to the parameter the value of the binding rather than the actual binding object.
A called bounded task flow can accept input parameters from the task flow that calls it or from a task flow binding.
To pass an input parameter to a bounded task flow, you specify one or more of the following:
Input parameters on the task flow call activity in the calling task flow: input parameters specify where the calling task flow stores parameter values.
Input parameter definitions on the called bounded task flow: input parameter definitions specify where the called bounded task flow can retrieve parameter values at runtime.
Specify the same name for the input parameter that you define on the task flow call activity in the calling task flow and the input parameter definition on the called bounded task flow. Do this so you can map input parameter values to the called bounded task flow.
If you do not specify an EL expression to reference the value of the input parameter, the EL expression for value defaults to the following at runtime:
#{pageFlowScope.parmName}
where parmName
is the value you entered for the input parameter name.
In an input parameter definition for a called bounded task flow, you can specify an input parameter as required. If the input parameter does not receive a value at runtime or design time, the task flow raises a warning in a log file of the MAF application that contains the task flow. An input parameter that you do not specify as required can be ignored during task flow call activity creation.
Task flow call activity input parameters can be passed by reference or passed by value when calling a task flow using a task flow call activity (see Specifying Input Parameters on a Task Flow Call Activity). By default, primitive types (for example, int
, long
, or boolean
) are passed by value (pass-by-value
A called task flow can return values to the task flow that called it when it exits. For more information, see Configuring a Return Value from a Bounded Task Flow.
When passing an input parameter to a bounded task flow, you define values on both the calling task flow and the called task flow.
Before you begin
Create a calling and called task flow: the calling task flow can be bounded or unbounded. The called task flow must be bounded. For more information about creating task flows, see How to Create a Task Flow.
Add a task flow call activity to the calling task flow.
Figure 11-13 shows an example where the view activity passes control to the task flow call activity.
Figure 11-13 Calling Task Flow
To pass an input parameter to a bounded task flow:
At runtime, the called task flow can to use the input parameter. If you specified pageFlowScope
as the value in the input parameter definition for the called task flow, you can use the parameter value anywhere in the called bounded task flow. For example, you can pass it to a view activity on the called bounded task flow.
Upon completion, OEPE writes entries to the source files for the calling task flow and called task flow based on the values that you select.
This example shows an input parameter definition specified on a a bounded task flow.
<task-flow-definition id="sourceTaskflow"> ... <input-parameter-definition> <name>inputParameter1</name> <value>#{pageFlowScope.parmValue1}</value> <class>java.lang.String</class> </input-parameter-definition> ... </task-flow-definition>
This example shows the input parameter metadata for the task flow call activity that calls the bounded task flow shown in this example. At runtime, the task flow call activity calls the bounded task flow and passes it the value specified by its value element.
<task-flow-call id="taskFlowCall1"> ... <input-parameter> <name>inputParameter1</name> <value>#{pageFlowScope.newCustomer}</value> <pass-by-value/> </input-parameter> ... </task-flow-call>
You configure a return value definition on the called task flow and add a parameter to the task flow call activity in the calling task flow that retrieves the return value at runtime.
Before you begin
Create a bounded or unbounded task flow (calling task flow) and a bounded task flow (called task flow). For more information, see How to Create a Task Flow.
To configure a return value from a called bounded task flow:
Upon completion, OEPE writes entries to the source files for the calling task flows that you configured.
This example shows an example entry that OEPE writes to the source file for the calling task flow.
<task-flow-call id="taskFlowCall1"> <return-value id="__3"> <name id="__4">returnValue1</name> <value id="__2">#{pageFlowScope.ReturnValueDefinition}</value> </return-value> </task-flow-call>
The next example shows an example entry that OEPE writes to the source file for the called task flow.
<return-value-definition id="__2"> <name id="__3">returnValue1</name> <value>#{pageFlowScope.ReturnValueDefinition}/</value> <class>java.lang.String</class> </return-value-definition>
At runtime, the called task flow returns a value. If configured to do so, the task flow call activity in the calling task flow retrieves this value.
When you create a MAF application, OEPE automatically creates a view project to go with the assembly project and application project. You can also create additional view projects. The following sections discuss these important aspects of creating and working with views:
Getting familiar with the MAF AMX page structure (see How to Work with MAF AMX Pages)
Dragging and dropping components onto an MAF AMX page (see Adding UI Components)
Adding data controls to a view (see Adding Data Controls to the View)
An MAF AMX page is represented by an XML file. The following is a basic structure of the MAF AMX file:
<amx:view> <amx:panelPage id="pp1"> <amx:facet name="header"> <amx:outputText id="ot1" value="Welcome"/> … </amx:facet> </amx:panelPage> </amx:view>
With the exception of data visualization components (see Providing Data Visualization), UI elements are declared under the <amx>
namespace.
For more information, see What Happens When You Create an MAF AMX Page.
MAF AMX files are contained in the View project of the MAF application. You create these files using the New MAF Page dialog.
MAF offers two alternative ways of creating an MAF AMX page:
From the New menu (File > New > MAF Page)
By right-clicking the ViewContent folder of the View project and selecting New > MAF Page
Before you begin
To create an MAF AMX page, the MAF application must include a View project folder (see Getting Started with MAF Application Development). Files created outside the ViewContent folder of the View project will not be included in the deployed application.
To create an MAF AMX page from the file menu:
From the top-level menu in OEPE, click File, and then select New > MAF Page.
In the New MAF Page dialog, browse to the View folder for the MAF application for which you are creating the AMX page. (Note that you may have more than one View project in an application.)
Enter a name (or accept the default) and, if needed, a location for your new file.
Optionally, you may select which facets your new MAF AMX page will include as a part of the page layout:
Header
Primary
Secondary
Footer
For more information, see What Happens When You Create an MAF AMX Page and How to Use a Facet Component.
Note that when you select or deselect a facet, the image representing the page changes dynamically to reflect the changing appearance of the page.
Figure 11-15 Create New MAF Page Dialog
MAF retains your page facet selection and applies it to each subsequent invocation of the New MAF AMX Page dialog.
Click Finish on the New MAF AMX Page dialog.
To create an MAF AMX page from a View component of the task flow:
When you use the Create MAF AMX Page dialog to create an MAF AMX page, OEPE creates the physical file and adds it to the ViewContent
directory of the View Controller project.
In the Project Explorer that Figure 11-16 shows, the ViewContent
node contains a newly created MAF AMX file called department.amx
Figure 11-16 MAF AMX File in Project Explorer
OEPE also adds the code necessary to import the component libraries and display a page. This code is illustrated in the Source editor shown in Figure 11-16.
If you create a page with all the facets selected, note the following:
The header is created with an Output Text component because this component is typically used for the page title.
The primary and secondary actions are created with Button components because it is a typical pattern.
Since there is no single dominant pattern for the footer, it is created with an Output Text component by default because that component is used in some patterns and it prevents OEPE from generating the initial code with audit violation.
Adding either the primary or secondary action without adding the header facet still causes the header section to appear in the Page Facets section of Create MAF AMX Page dialog.
Figure 11-17 shows the Page Facet section of the Create MAF AMX Page dialog without any facets selected and Figure 11-18 shows the Preview pane with the generated MAF AMX code.
Figure 11-17 Creating MAF AMX Page Without Selected Facets
Figure 11-18 MAF AMX Page Without Facets
MAF AMX supports OEPE's Go to Page Definition functionality that enables you to navigate to the MAF AMX page definition (see Figure 11-19 and What You May Need to Know About Generated Drag and Drop Artifacts) by using a context menu that allows you to locate and edit the binding information quickly.
Figure 11-19 Page Definition editor
You can invoke the context menu that contains the Go to Page Definition option from the following:
Source editor, as Figure 11-20 shows.
Figure 11-20 Go to Page Definition from Source Editor
Application window, by right-clicking the page, selecting Open With > Other, and then selecting Page Definition Editor, as Figure 11-21 shows.
Figure 11-21 Go to Page Definition from Application Window
You can enable sharing of contents of MAF AMX pages. Fragment (fragment
) is a dynamic declarative component that allows for reusable parts of an MAF AMX page elements, including attributes and facets, to be inserted into the content represented by a template. This enables you to standardize the look and feel of your application by reusing the Fragment template across various pages within the application.
You can drag and drop an MAF AMX fragment file ( .amxf
) onto an MAF AMX page or another fragment file to create a reference to the fragment and to define its attributes. The fragment file resides inside your project and you can drop it from the Project Explorer window into a target source file that is currently open in the Source editor.
Before you begin
Ensure that the MAF application includes a View project.
If the View project does not contain an MAF AMX page or MAF AMX page task flow from which to create a page, you can invoke the Create MAF AMX Page dialog by double-clicking a view icon in a task flow diagram (see Creating MAF AMX Pages).
To create a Fragment from the File menu:
This example shows an MAF AMX fragment file called fragment1.amxf.
<amx:fragmentDef xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:amx="http://xmlns.oracle.com/adf/mf/amx" xmlns:dvtm="http://xmlns.oracle.com/adf/mf/amx/dvt"> <fragment xmlns="http://xmlns.oracle.com/adf/mf/amx/fragment" id="f1"> <description id="d1">Description of the fragment</description> <facet id="f2"> <description id="d4">Description of the facet</description> <facet-name id="f3">facet1</facet-name> </facet> <attribute id="a1"> <description id="d2">Description of an attribute</description> <attribute-name id="a2">text</attribute-name> <attribute-type id="at1">String</attribute-type> <default-value id="d3">defaultValue</default-value> </attribute> </fragment> <amx:panelGroupLayout id="pgl1"> <amx:facetRef facetName="facet1" id="fr1"/> <amx:outputText value="#{text}" id="ot1"/> </amx:panelGroupLayout> </amx:fragmentDef>
To include the contents of the fragment in the MAF AMX page, you create a Fragment component (see How to Use the Fragment Component) and set its src
attribute to the fragment file of your choice. The example below shows a fragment
element added to an MAF AMX page. This element points to the fragment1.amxf
as its page contents. At the same time, the facetRef
element, which corresponds to the Facet Definition MAF AMX component, points to facet1
as its facet
(MAF AMX Facet component). The facetRef
element can only be specified in the .amxf
file within the fragmentDef
. You can pass attributes to the facetRef
by specifying the MAF AMX attribute
element as its child, which allows you to pass an EL variable from the Fragment to a Facet through the attribute
's value.
<?xml version="1.0" encoding="UTF-8" ?> <amx:view xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:amx="http://xmlns.oracle.com/adf/mf/amx" xmlns:dvtm="http://xmlns.oracle.com/adf/mf/amx/dvt"> <amx:panelPage id="pp1"> <amx:panelGroupLayout layout="vertical" id="itemPgl" styleClass="amx-style-groupbox"> <amx:fragment id="f1" src="/simpleFragment.amxf" <amx:attribute id="a1" name="text" value="defaultValue" /> <amx:facet name="facet"> <amx:outputText id="ot5" value="Fragment"/> </amx:facet> </amx:fragment> </amx:panelGroupLayout> </amx:panelPage> </amx:view>
The Fragment supports the following:
Embedded popups (see How to Use a Popup Component).
Reusable user interface that can be placed on one or more other parent pages or fragments. This allows you to create a component that is composed of other components without bindings.
Definition of its own facets. This allows you to create a component such as a layout component that defines a header facet, summary facet, and detail facet, with each facet having its own style class as well as look and feel.
Data model with both attributes and collections.
MAF sample applications called FragmentDemo and CompGallery demonstrate how to create and use the fragments. These sample applications are available from File > New > MAF Examples.
After you create an MAF AMX page, you can start adding MAF AMX UI components and data controls to your page.
You can use the Palette to drag and drop MAF AMX components and MAF AMX data visualization components onto the page. OEPE then adds the necessary declarative page code and sets certain values for component attributes.
The Palette displays MAF AMX components by categories:
Control Flow
Activities
For information on adding and using specific components, see Creating and Using UI Components.
The Palette also displays MAF AMX data visualization components by categories:
Common, with the following subcategories:
Chart
Gauge
Map
Miscellaneous
Shared Child Tags
Other Type-Specific Child Tags, with the following subcategories:
Chart
Gauge
NBox
Thematic Map
Timeline
Sunburst and Treemap
Before you begin
The MAF application must include a View project, which may or may not contain an MAF AMX page or MAF AMX page task flow from which to create a page.
As described in Creating MAF AMX Pages, you can invoke the Create MAF AMX Page dialog by double-clicking a view icon in a task flow diagram or by selecting New > MAF Page.
To add UI components to a page:
You can create databound UI components in an MAF AMX view by dragging data control elements from the Data Controls window and dropping them into either the Structure window or the Source editor. When you drag an item from the Data Controls window to either of these places, OEPE invokes a context menu of default UI components available for the item that you dropped. When you select the desired UI component, OEPE inserts it into an MAF AMX page. In addition, OEPE creates the binding information in the associated page definition file. If such file does not exist, then OEPE creates one. MAF provides a visual indicator for dropping data controls to inform you of the location of the new data control
A data control can only be dropped at a location allowed by the underlying XML schema.
Depending on the approach you take, you can insert different types of data controls into the Structure window of an MAF AMX page. The data controls available from the Tags pane of the Palette are shown in Figure 11-24.
Figure 11-24 HTML Control Tags from the Palette
Dropping an attribute of a collection lets you create various input and output components. You can also create Button and Link components by dropping a data control operation on a page.
The respective action listener is added in the MAF AMX Button for each of these operations.
The data control attributes and operations can be dropped as one or more of the following MAF AMX UI components (see Creating and Using UI Components):
Button
Link
Input Date
Input Date with Label
Input Text
Input Text with Label
Output Text
Output Text with Label
Iterator
List Item
List View
Select Boolean Checkbox
Select Boolean Switch
Select One Button
Select One Choice
Select One Radio
Select Many Checkbox
Select Many Choice
Convert Date Time
Convert Number
Form
Read Only Form
Parameter Form
The following Date and Number types are supported:
java.util.Date
java.sql.Timestamp
java.sql.Date
java.sql.Time
java.lang.Number
java.lang.Integer
java.lang.Long
java.lang.Float
java.lang.Double
For information on how to use the Data Controls window in OEPE, see Creating Databound UI Components from the Data Controls Palette.
If your MAF AMX page already contains a Panel Form Layout component or does not require to have all the fields added, you can drop individual attributes from a data control. Depending on the attributes types, different data binding menu options are provided as follows:
Date
This category provides options for creating MAF Input Date and MAF Input Date with Label controls. Figure 11-25 shows the context menu for adding date controls that appears when you drag an attribute from the Data Controls window onto the Source editor or Structure window of an MAF AMX page.
Figure 11-25 Context Menu for Date Controls
Single Selection
This category provides options for creating the following controls:
MAF Select One Button
MAF Select One Choice
MAF Select One Radio
MAF Select Boolean Checkbox
MAF Select Boolean Switch
If you are working with an existing MAF AMX page and you select MAF Select One Button or MAF Select One Choice option, an appropriate version of the Edit List Binding dialog is displayed (see Figure 11-26). If you drop a control onto a completely new MAF AMX page, the Edit Action Binding dialog opens instead. After you click OK, the Edit List Binding dialog opens.
The Edit List Binding or Edit Boolean Binding dialog appears every time you drop any data control attributes as any of the single selection or boolean selection components, respectively.
Figure 11-26 Edit List Binding Dialog for Select One Button and Choice Controls
If you select MAF Select One Radio option, another version of the Edit List Binding dialog is displayed, as shown in Figure 11-27.
Figure 11-27 Edit List Binding Dialog for Select One Radio Control
If you select MAF Select Boolean Checkbox or MAF Select Boolean Switch option, another version of the Edit List Binding dialog is displayed, as shown in Figure 11-28.
Figure 11-28 Edit List Binding Dialog for Select Boolean Checkbox and Switch Controls
Text
MAF Input Text
MAF Input Text with Label
MAF Output Text
MAF Output Text with Label
Figure 11-29 shows the context menu for adding text controls that appears when you drag an attribute from the Data Controls window onto the Source editor or Structure window of an MAF AMX page.
Figure 11-29 Context Menu for Text Controls
In addition to attributes, you can drag and drop operations and custom methods. Depending on the type of operation or method, different data binding menu options are provided, as follows:
Operation
This category is for data control operations. It provides the following options (see Figure 11-30):
MAF Button
MAF Link
MAF Parameter Form
Figure 11-30 Context Menu for Operations
If you drop an operation or a method as a child of the List View control, the context menu does not appear and the List Item is created automatically because no other valid control can be dropped as a direct child of the List View control. OEPE creates a binding similar to the following for the generated List Item:
<amx:listItem actionListener="#{bindings.getLocation.execute}"/>
Method
This category is for custom methods. It provides the following options (see Figure 11-31):
MAF Button
MAF Link
MAF Parameter Form
Figure 11-31 Editing a Method call with the General Tab of the Properties pane
The MAF Parameter Form option allows you to choose the method or operation arguments to be inserted in the form, as well as the respective controls for each of the arguments (see Figure 11-32).
Figure 11-32 Edit Form Fields Dialog
The following data bindings are generated after you select the appropriate options in the Edit Form Fields dialog:
<amx:panelFormLayout id="pfl1"> <amx:inputText id="it1" value="#{bindings.empId.inputValue}" label="#{bindings.empId.hints.label}" /> </amx:panelFormLayout> <amx:commandButton id="cb1" actionListener="#{bindings.ExecuteWithParams1.execute}" text="ExecuteWithParams1" disabled="#{!bindings.ExecuteWithParams1.enabled}"/>
For more information about generated bindings, see What You May Need to Know About Generated Bindings.
The following are supported control types for the MAF Parameter Form:
MAF Input Date
MAF Input Text
You can drag and drop collections. Depending on the type of collection, different data binding menu options are provided, as follows:
Multiple Selection
This category provides options for creating multiple selection controls. The following controls can be created under this category (see Figure 11-33):
MAF Select Many Checkbox
MAF Select Many Choice
Figure 11-33 Context Menu for Multiple Selection Controls
If you select either Select Many Choice or Select Many Checkbox as the type of the control you want to create, the Edit List Binding dialog is displayed (see Figure 11-34).
Figure 11-34 Edit List Binding Dialog for Multiple Selection Controls
Form
This category is used to create the MAF AMX Panel Form controls. When you select Form from the HTML pane of the Palette, OEPE displays the New Form dialog (see Figure 11-35):
Figure 11-35 New Form Dialog
Select the method (get
or post
) and enter the desired action. OEPE adds a basic HTML form tag to the source; you can edit the Value fields from the Properties pane (see Figure 11-36).
Figure 11-36 Edit Form Fields Dialog for MAF Form
Iterator
This provides an option for creating the MAF AMX Iterator with child components (see Figure 11-37).
Figure 11-37 Context Menu for Iterator Control
If you select Generate an Iterator with content from data controls, OEPE displays a Browse link from which you can select the file that contains the content.
The following data bindings are generated after you select the appropriate options in the Edit Iterator dialog:
<amx:iterator id="i1" var="row" value="#{bindings.jobs.collectionModel}"> <amx:panelLabelAndMessage id="plam6" label="#{bindings.jobs.hints.jobId.label}"> <amx:outputText id="ot6" value="#{row.jobId}" /> </amx:panelLabelAndMessage> <amx:panelLabelAndMessage id="plam5" label="#{bindings.jobs.hints.title.label}"> <amx:outputText id="ot5" value="#{row.title}" /> </amx:panelLabelAndMessage> <amx:inputText id="it1" value="#{row.bindings.minSalary.inputValue}" label="#{bindings.jobs.hints.minSalary.label}" /> <amx:inputText id="it2" value="#{row.bindings.maxSalary.inputValue}" label="#{bindings.jobs.hints.maxSalary.label}" /> </amx:iterator>
The following are supported controls for MAF Iterator:
MAF Input Text
MAF Output Text
List View
This provides an option for creating the MAF AMX List View with child components (see Figure 11-38).
Figure 11-38 Context Menu for List View Control
Table 11-4 lists the supported List Formats that are displayed in the ListView Gallery.
Table 11-4 List Formats
Format | Element Row Values |
Simple |
Main-Sub Text |
Start-End |
Quadrant |
Table 11-5 shows sample bindings that are added to an MAF AMX page when components are dropped.
Table 11-5 Sample Data Bindings
Component | Data Bindings |
Button |
<amx:commandButton id="commandButton1" actionListener="#{bindings.FindContacts.execute}" text="FindContacts" disabled="#{!bindings.FindContacts.enabled}"> </amx:commandButton> |
Link |
<amx:commandLink id="commandLink1" actionListener="#{bindings.FindContacts.execute}" text="FindContacts" disabled="#{!bindings.FindContacts.enabled}"> </amx:commandLink> |
Input Date with Label |
<amx:inputDate id="inputDate1" value="#{bindings.timeStamp.inputValue}" label="#{bindings.timeStamp.hints.label}"> </amx:inputDate> |
Input Date |
<amx:inputDate id="inputDate1" value="#{bindings.timeStamp.inputValue}"> </amx:inputDate> |
Input Text with Label |
<amx:inputText id="inputText1" value="#{bindings.contactData.inputValue}" label="#{bindings.contactData.hints.label}"> </amx:inputText> |
Input Text |
<amx:inputText id="inputText1" value="#{bindings.contactData.inputValue}" simple="true"> </amx:inputText> |
Output Text |
<amx:outputText id="outputText1" value="#{bindings.contactData.inputValue}"> </amx:outputText> |
Output Text with Label |
<amx:panelLabelAndMessage id="panelLabelAndMessage1" label="#{bindings.contactData.hints.label}"> <amx:outputText id="outputText1" value="#{bindings.contactData.inputValue}"/> </amx:panelLabelAndMessage> |
Select Boolean Checkbox |
<amx:selectBooleanCheckbox id="selectBooleanCheckbox1" value="#{bindings.contactData.inputValue}" label="#{bindings.contactData.label}"> </amx:selectBooleanCheckbox> |
Select Boolean Switch |
<amx:selectBooleanSwitch id="selectBooleanSwitch" value="#{bindings.contactData.inputValue}" label="#{bindings.contactData.label}"> </amx:selectBooleanSwitch> |
Select One Button |
<amx:selectOneButton id="selectOneButton1" value="#{bindings.contactData.inputValue}" label="#{bindings.contactData.label}" required="#{bindings.contactData.hints.mandatory}"> <amx:selectItems value="#{bindings.contactData.items}"/> </amx:selectOneButton> |
Select One Choice |
<amx:selectOneChoice id="selectOneChoice1" value="#{bindings.contactData.inputValue}" label="#{bindings.contactData.label}"> <amx:selectItems id="selectItems1" value="#{bindings.contactData.items}"/> </amx:selectOneChoice> |
Select Many Checkbox |
<amx:selectManyCheckbox id="selectManyCheckbox1" value="#{bindings.AssetView.inputValue}" label="#{bindings.AssetView.label}"> <amx:selectItems id="selectItems1" value="#{bindings.AssetView.items}"/> </amx:selectManyCheckbox> |
Select One Radio |
<amx:selectOneRadio id="selectOneRadio1" value="#{bindings.contactData.inputValue}" label="#{bindings.contactData.label}" <amx:selectItems id="selectItems1" value="#{bindings.contactData.items}"/> </amx:selectOneRadio> |
Select Many Choice |
<amx:selectManyChoice id="selectManyChoice1" value="#{bindings.AssetView.inputValue}" label="#{bindings.AssetView.label}"> <amx:selectItems id="selectItems1" value="#{bindings.AssetView.items}"/> </amx:selectManyChoice> |
The first drag and drop event generates the following directories and files:
Figure 11-39 shows a sample DataBindings.cpx
file generated upon drag and drop.
Figure 11-39 DataBindings.cpx File in Source View
The DataBindings.cpx
files define the binding context for the entire MAF AMX application feature and provide the metadata from which the binding objects are created at runtime. An MAF AMX application feature may have more than one DataBindings.cpx
file if a component was created outside of the project and then imported. These files map individual MAF AMX pages to page definition files and declare which data controls are being used by the MAF AMX application feature. At runtime, only the data controls listed in the DataBindings.cpx
files are available to the current MAF AMX application feature.
OEPE automatically creates a DataBindings.cpx
file in the default package of the ViewController project when you for the first time use the Data Controls window to add a component to a page or an operation to an activity. Once the DataBindings.cpx
file is created, OEPE adds an entry for the first page or task flow activity. Each subsequent time you use the Data Controls window, OEPE adds an entry to the DataBindings.cpx
for that page or activity, if one does not already exist.
Once OEPE creates a DataBindings.cpx
file, you can open it in the Source view (see Figure 11-39) or the editor.
The Page Mappings (pageMap
) section of the file maps each MAF AMX page or task flow activity to its corresponding page definition file using an ID. The Page Definition Usages (pageDefinitionUsages
) section maps the page definition ID to the absolute path for page definition file in the MAF AMX application feature. The Data Control Usages (dataControlUsages
) section identifies the data controls being used by the binding objects defined in the page definition files. These mappings allow the binding container to be initialized when the page is invoked.
You can use the editor to change the ID name for page definition files or data controls by double-clicking the current ID name and editing inline. Doing so will update all references in the MAF AMX application feature. Note, however, that OEPE updates only the ID name and not the file name. Ensure that you do not change a data control name to a reserved word.
You can also click the DataBindings.cpx
file's element in the Structure window and then use the Properties window to change property values.
Figure 11-40 shows a sample PageDef
Figure 11-40 PageDef File
Page definition files define the binding objects that populate the data in MAF AMX UI components at runtime. For every MAF AMX page that has bindings, there must be a corresponding page definition file that defines the binding objects used by that page. Page definition files provide design-time access to all the bindings. At runtime, the binding objects defined by a page definition file are instantiated in a binding container, which is the runtime instance of the page definition file.
The first time you use the Data Controls window to add a component to a page, OEPE automatically creates a page definition file for that page and adds definitions for each binding object referenced by the component. For each subsequent databound component you add to the page, OEPE automatically adds the necessary binding object definitions to the page definition file.
By default, the page definition files are located in the mobile.PageDefs
package in the Application Sources node of the ViewController project. If the corresponding MAF AMX page is saved to a directory other than the default, or to a subdirectory of the default, then the page definition is also be saved to a package of the same name.
For information on how to open a page definition file, see Accessing the Page Definition File. When you open a page definition file in the editor, you can view and configure bindings, contextual events, and parameters for an MAF AMX page using the following tabs:
Bindings and Executables: this tab shows three different types of objects: bindings, executables, and the associated data controls. Note that data controls do not display unless you select a binding or executable.
By default, the model binding objects are named after the data control object that was used to create them. If a data control object is used more than once on a page, OEPE adds a number to the default binding object names to keep them unique.
Contextual Events: you can create contextual events to which artifacts in an MAF AMX application feature can subscribe.
Parameters: parameter binding objects declare the parameters that the page evaluates at the beginning of a request. You can define the value of a parameter in the page definition file using static values or EL expressions that assign a static value.
When you click an item in the editor (or the associated node in the Structure window), you can use the Properties window to view and edit the attribute values for the item, or you can edit the XML source directly by clicking the Source tab.
OEPE's Bindings tab (see Figure 11-41) is available in the MAF AMX Editor. It displays the data bindings defined for a specific MAF AMX page. If you select a binding, its relationship to the underlying Data Control are shown and the link to the PageDef
file is provided.
Figure 11-41 Bindings Tab
When you delete or cut an MAF AMX component from the Structure window, unused bindings are automatically removed from your page.
Deleting a component from the Source editor does not trigger the removal of bindings.
Figure 11-42 demonstrates the deletion of a List View component that references bindings. Upon deletion, the related binding entry is automatically removed from the corresponding PageDef.xml
file.
Figure 11-42 Deleting Bound Components from Page
Figure 11-43 demonstrates the removal of the List View component by cutting it from the page.
Figure 11-43 Cutting Bound Components from Page
After clicking Cut, you are presented with the Confirm Removal of Bindings dialog that prompts you to choose whether or not to delete the corresponding bindings, as shown in Figure 11-44.
Figure 11-44 Confirm Removal of Bindings Dialog
MAF generates a unique element identifier (id
) and automatically inserts it into the MAF AMX page when an element is added by dropping a component from the Palette, or by dragging and dropping a data control. This results in a valid identifier in the MAF AMX page that differentiates each component from others, possibly similar components within the same page.
MAF provides an identifier audit utility that does the following:
Checks the presence and uniqueness of identifiers in an MAF AMX page.
If the identifier is not present or not unique, an error is reported for each required id
attribute of an element.
Provides an automatic fix to generate a unique id
for the element when a problem with the identifier is reported.
Figure 11-45 and Figure 11-46 show the identifier error reporting in the Source editor and Structure pane respectively.
Figure 11-45 Element Identifier Audit in Source Editor
Figure 11-46 Element Identifier Audit in Structure Pane
In addition to the id
, the audit utility checks the popupId
and alignId
attributes of the Show Popup Behavior operation (see How to Use a Popup Component).
Figure 11-47 and Figure 11-48 show the Show Popup Behavior's Popup Id and Align Id attributes error reporting in the Source Editor respectively.
Figure 11-47 Popup Id Attribute Audit in Source Editor
Figure 11-48 Align Id Attribute Audit in Source Editor
The security architecture used by MAF guarantees that the browser hosting an MAF AMX page does not have access to the security information needed to make connections to a secure server to obtain its resources. This has a direct impact on AJAX calls made from MAF AMX pages: these calls are not supported, which poses limitations on the use of Java Script from within MAF AMX UI components. Communication with the server must occur from the embedded Java code layer.
