This section describes the following techniques for designing accessible reports using the BI Publisher layout editor.
You define the title of a report at the same time as you save the report layout. You can also rename the report at a later time.
You can define alternative text for images so that they are describable in accessibility mode.
To define alternative text for an image:
You can define a text summary to describe a table within a report.
To define summary table text:
Table row headers summarize each row in a table. The layout editor automatically includes table row headers on all inserted tables. No further action is required.
