Master Items: The parent item instance under which the same items post.
For example, a restaurant chain offers a one-pound beef hamburger with cheese. Each restaurant location can name or refer to this hamburger differently, such as cheeseburger or beef burger, 1LB. By default, reports and calculations handle these two entries as completely different entities. To consolidate the two entries, you can create a Master Menu Item named Beef Cheeseburger, 1LB, and then link the two entries to the master item. Reporting and Analytics then always treats posted entries for cheeseburger and beef burger, 1LB as a Beef Cheeseburger, 1LB order.
Master Groups: A grouping of locations for assigning master items and alignment rules. Each Master Group must be assigned at least one Master Store. Each location can only be assigned to one Master Group for each item type.
For example, a restaurant chain offers fast food stores and seated-diner stores. The chain can create a Master Group for their fast food stores and for their seated diner stores, and then assign a headquarters store to each group. This allows the restaurant to control item alignment for fast food stores separately from seated-diner stores.
Master Store: A location that sets default Master Items for selected item types for their assigned Master Group. You can only assign one master store for each item type.
For example, a restaurant chain configures a Master Group for their fast food chain, and assigns the Redwood Shores location as the master store for all Front-of-House item categories, such as menu items and discounts. When a new menu item is introduced to the system in the Redwood Shores location, Reporting and Analytics treats the Redwood Shores instance as the Master Item. When a new menu item is introduced to the system in another location, Reporting and Analytics attempts to align the new menu item to existing Master Items, and you must either manually configure a Master Item or create an instance of the menu item at the Redwood Shores location.
Figure 5-2 Example Master Group and Master Store
Parent topic: Item Alignment
