Reporting and Analytics enables you to export data for use in custom reports and third-party applications. You map data values in Reporting and Analytics so third-party applications can process the exported data. For example, a third-party application uses a value of 100 to define hamburgers. The workstation uses a value of 1015 for hamburgers. You can map an external value of 100 to the exported data so the third-party application can process the data.
