As a System Sales Summary report example, you selected the CashTotals data category, so you type Cash in the External Reference field.
As an example for exporting data for a third-party application, you type 100 because that is the value the application uses to define an item such as hamburgers.
If you are mapping data for System Sales Summary reports, select the source according to the following table:
| Category | Source |
CashTotals |
Tender Media |
Deposits |
Tender Media |
PaidIn |
Tender Media |
PaidOut |
Tender Media |
TipsPaidSVC |
Service Charge |
TipsPaidTender |
Tender Media |
GiftCards |
Menu Item |
GiftCards |
Service Charge |
As a System Sales Summary report example, you specified Cash as the external reference and you selected Tender Media as the information source. If the workstation reference number for the Cash key is 101, type 101 in the By POS Ref field.
As an example for exporting data for use by a third-party application, type 1015 because that is the value the workstation uses to define an item such as hamburgers.
Related Topics
