The app shows the revenue center settings defined in the POS workstation database for your organization. The documentation for your POS workstation provides more information on settings. To use an existing menu item class, select Existing, and then click Select. Select the menu item class, and then click OK. To use a new menu item class, select New, and then enter the menu item class number.
To change a menu item name for all locations, enter the new name, and then click Set. To change major and family groups, click Select, and then select the new groups.
To schedule the changes to take effect at a later time, select Create a new batch to publish, and then specify the date and time.
To add the changes to a batch, select Add to an existing batch, and then select the batch from the table.
Parent topic: Enterprise Maintenance Services
