The EMS app enables you to manage POS workstation number ranges for menu items and discounts. You specify number range settings when you add menu items and discounts to locations.
- Log in to the EMS app, and then click Number Ranges.
- To add a range, click Add, and then specify range settings.
For example, you can create a range named Appetizers. You can specify 1000 as the start of the range and 2000 as the end. The numbers within the range correspond to appetizer menu items.
- To edit a range, select the range from the table, and then click Edit.
- To delete a range, select the range from the table, and then click Delete.
