Reporting and Analytics appends the suffix to items aligned with the Master Store. This allows you to immediately identify the alignment status of items when performing manual alignment. For example, if you configure the Front of House Master Group with the FOH suffix, and then set a Master Item for COCKTAIL, Reporting and Analytics appends the suffix and shows the item as COCKTAIL.FOH.
Parent topic: Item Alignment
