Assigning Locations as Master Stores
  1. In Reporting and Analytics, click Admin, click Warehouse, click Miscellaneous, and then click Master Groups.
  2. Select a Master Group, and then click Assign Store Master.
  3. Click Add, and then select a Location from the drop-down list.
  4. Select the item types or groups to designate the Master Items. You cannot designate an item type or group as a Master Item if it has been set for another Master Store in the same Master Group.
    • For Food and Beverage organizations, you must select Menu Item, Major Group, and Family Group together.
    • For Hotel and Resort organizations, you must select the following sets together:
      • Rate Category and Rate Class
      • Product and Package Forecast Group
      • Revenue Type and Revenue Group
      • Promotion and Marketing Program
      • Promo Service and Promotion
      • Event Type and Meal Type
      • Trans Subgroup and Trans Group
      • Room Category, Room Class, and Rate Category
      • Catering Item, Catering Item Class, and Revenue Type
  5. You can select Assign as location if you deactivate the location as a Master Store.
