This topic provides instructions for creating a backup and then running the uninstallation wizard to remove Oracle MICROS Enterprise Back Office. Refer to the Oracle WebLogic help and the Oracle Business Intelligence help when uninstalling the respective software.
myMicros
installation directory.myMicros
folder to create a backup.installation path\myMicros\Uninstall_myMicros\
and double-click Change myMicros Installation
.myMicros
folder to remove all files that were not removed by the uninstallation wizard.myMicros
.myMicros
folder to remove all files that were not removed by the uninstallation wizard.Parent topic: Uninstallation
