Perform the following steps to manually re-deploy applications without using the update functionality in the Oracle WebLogic Administration Console.
In the Oracle WebLogic console, navigate to the Summary of Deployments page, and then delete the applications that you want to re-deploy.
Click Install and use the following table as a reference to deploy the applications:
Table 11-1 Application Deployment Reference
EAR/WAR Location
Deployment Target
Deployment Name
INSTALLATION_DIR\myPortal\portal.ear
micros_cluster
portal
INSTALLATION_DIR\OBIEE\analyticsRes.war
bi_cluster
analyticsRes
INSTALLATION_DIR\OBIEE\LogoutApp.war
bi_cluster
logoutApp
INSTALLATION_DIR\OBIEE\obieeWebService.war
bi_cluster
ObieeWebService
Navigate to the Enterprise Application Archive (EAR) or Web Application Archive (WAR) file for the application.
Select Install this deployment as an application.
Select the deployment target corresponding to the selected EAR or WAR file.
Enter the deployment name corresponding to the selected EAR or WAR file.
Select Copy this application onto every target for me.
Click Activate Changes, click Start, and then click Servicing all requests.
If the deployment times out, increase the Max Stuck Thread Time server environment parameter to increase the time-out allowance. Deployment Time Outs contains information and instructions.
