This release contains the following features and changes for Inventory Management
Parent topic: Features and Updates
This release contains a new version of the Oracle MICROS Inventory Management Mobile Solutions client application that is compatible with the Oracle MICROS Tablet 700 Series.
Parent topic: Inventory Management
This release contains a new version of the Oracle MICROS Inventory Management Mobile Solutions application that is compatible with the Oracle MICROS Tablet 700 Series. These tablets are not compatible with the legacy Mobile Solutions 2010 client.
Inventory Management now queries the v$nls_parameters system table to determine its charset. If the system table is not accessible, the system looks for the configuration in web.config.
On the Order Cycles page, you can now click Download Xls Template to download a spreadsheet template. You can configure your order cycle settings in the spreadsheet, export the spreadsheet in .CSV format, and then import the configurations using the ordercycle.myinv.languagecode-countrycode.excel.template templates for B2B order cycles.
This patch installs and supports the United States Department of Agriculture National Nutrient Database for Standards Reference release 28.
You can now manage allergen and additive information for items and recipes. Inventory Management includes a default set of allergens and additives that can be assigned to items and recipes.
Company property in the SOAP header to support multi-tenant environments.
Additives data structure and method to support handling allergens and additives.
The Inventory Management Point-of-Sale Web Services API contains further information.
