This module is only available if the Transfers To/From web user right is set. Issue Requests and Transfers provide more information if the user right is not configured for your organization.
You can set up transfers to and from specified cost centers within the organization. The general idea is that location A creates a Transfer To to send goods to location B, whereas location B creates a Transfer From to receive goods from location A. In previous versions of Inventory Management, this task was broken into two separate modules. Regardless of how your organization is configured, the concepts are the same.
Depending on whether you are location A or location B determines your perspective toward this module. If you are the requesting location, you request a Transfer From another location. If you are the supplying location, you provide a Transfer To the location.
Determine how items are transferred
View any suspended, requested, delivered, declined, and booked transfers currently in the system
