Table 25-6 Transfer Settings
| Settings | Description |
Hide Filters on module start |
Select this option to prevent the system from showing available filters when first opening the page. |
Print Tax Summary on Transfer |
Select this option to have tax summary information printed on the transfer. |
Show Item Number in Search |
Select this option to show the item number in a search. |
Consider Transfer from in Forecast OOS |
Select this option to include the requested and delivered quantities in the Forecast Out of Stock page. |
Sorting |
Select the order in which the system sorts transfer details and the source of requested documents. |
Result Set Quantity |
Enter the number of transfer records to show, up to a maximum of 9,999. |
Show Report Selection for Printing |
Select this option to display a list of report types available for printing when booking a transfer. |
Parent topic: Settings
