Table 25-7 Waste Settings
| Setting | Description |
Hide Filters on module start |
Select this option to prevent the system from showing the available filters when first opening the page. |
Consider Depletion Rules for POS Waste |
Select this option to allow the POS Waste Check depletion to use Depletion Cost Centers. |
Show Item Number in Search |
Select this option to show the item number in a search. |
Sorting |
Select the order in which the system sorts waste documents. |
POS Waste Check Waste Group |
Select the Waste Group to which the system applies POS waste checks. |
Result Set Quantity |
Enter the number of Waste records to show, up to a maximum of 9,999. |
Parent topic: Settings
