This feature enables you to print a list of all items included in the selected recipes. This can be used as a general list of ingredients needed for an event.
- Click Production, click Event Menu Plan, click Suspended, and then use the filters to find an event menu plan.
- Click the appropriate Document to open it, click Print Recipe(s), select a template using Select Report, and then click OK.
