After creating a card program and card rule, generate and reserve card numbers to be printed for a specific program and rule. Gift and Loyalty uses card numbers as the account numbers.
This process does not forego the need to issue the cards before they are active, and you must avoid duplicate card numbers. Review existing numbers to make sure you are entering an unused range of card numbers.
Parent topic: Card and Account Numbers
