Eligibility rules...
Parent topic: Rule Configuration References
Eligibility rules are used to define which transactions are eligible for specific functions. The most common use is to define which transaction qualify for loyalty functions. Eligibility rules are also used to define what is eligible for Loyalty Awards and Coupon and what can be redeemed with specific accounts. Eligibility rules can be limited by time, items, or sales itemizers.
require a minimum guest check total to satisfy award requirements, or
calculate loyalty points based on the guest check total.
service charges
taxes
partial payments
Use with Loyalty Rule: Select to define which transactions are eligible to earn points in a loyalty program or to define which items can be discounted for an immediate discount award.
Use with Redemption Rule: Select to limit which items can be purchased with a stored value or pay with points program.
Use with Coupon Rule: Select to define which items can be discounted by a coupon.
Use with Stored Value Bonus Rule: Select to define which transactions qualify for a stored value bonus.
Include Service Charges: Select to include service charges when calculating the minimum check value or when calculating loyalty points. Do not select if the minimum check value calculates using the net transaction total.
Include Taxes: Select to include taxes when calculating the minimum check value or when calculating loyalty points. Do not select if the minimum check value calculates using the net transaction total.
Exclude Payment: Select to exclude partial payments applied to the transaction when calculating the minimum check value or when calculating loyalty points. Use this option to prevent situations where a guest makes a payment to the check using a gift card and receives points for the purchase.
Require Stored Value:
Num of Items in Transaction: minimum number of items in the specific transaction.
Num Combos in Transaction: minimum number of combo meals in the specific transaction.
Num Items in Transaction this Period: minimum number of times the item was included in a transaction over the current period
Num Combos in Transaction this Period: minimum number of times the combo meal was included in a transaction over the current period.
Never Expire: Do not allow unique items to be counted toward eligibility again.
Expire items after x periods: Unique items expire after a set number of periods worth of days have transpired since the date of purchase. For example, if you set unique items to expire after 3 periods and the rule uses weekly periods, the item expires exactly three weeks after the date of purchase.
Expire items after x rolling periods: Unique items expire after a set number of periods have passed after the current period. For example, if you set unique items to expire after 3 periods and the rule uses weekly periods, the item expires three weeks after the end of the current weekly period.
Reset all items after x periods: All unique items expire after a set number of periods worth of days have transpired since the date the first item was purchased.
Reset all items after x rolling periods: All unique items expire after a set number of periods have passed after the current period.
Parent topic: Eligibility Rule Configuration Reference
Add menu items, family groups, and major groups to an eligibility rule.
Menu Item POS Ref (Object Number): Qualify items based on the POS object number.
Menu Item Master: Qualify items aligned to a specific master item.
Major Group POS Ref (Object Number): Qualify items associated with a major group based on the POS object number.
Major Group Master: Qualify items associated or aligned with a master major group.
Family Group POS Ref (Object Number)Qualify items associated with a family group based on the POS object number.
Family Group Master: Qualify items associated or aligned with a master family group.
For family groups, select the master family group from the Master drop-down list.
For point-based loyalty rules:
Table 8-1 Discount and Qualified Applicability of Loyalty Point Calculation Methods
| Point calculation methods | Discountable | Qualified | ||
Per visit |
Not applicable |
Optional |
Per check value |
Not applicable |
Optional |
Number of selected items |
Not applicable |
Required |
Value of selected items |
Not applicable |
Required |
Number of unique selected items |
Not applicable |
Required |
If any selected item on check |
Not applicable |
Required |
New items this period |
Not applicable |
Required |
Additional points if selected |
Not applicable |
Required |
Use multiplier if selected |
Not applicable |
Optional |
Time rule only |
Not applicable |
Optional |
Additional points by visit |
Not applicable |
Optional |
Use multiplier threshold exceeded |
Not applicable |
Optional |
Per check value if any selected |
Not applicable |
Required |
Per defined check value |
Not applicable |
Required |
For coupon and award loyalty rules:
Table 8-2 Discount and Qualified Applicability of Coupon and Award Value Calculation Methods
| Value calculation methods | Discountable | Qualified | ||
Use POS Preset Discount (subtotal calc) |
Not applicable |
Not applicable |
Use Fixed Value Amount (subtotal calc) |
Not applicable |
Not applicable |
Use Percentage of Check Subtotal (subtotal calc) |
Not applicable |
Not applicable |
Use Percentage Up to Limit (subtotal calc) |
Not applicable |
Not applicable |
Use Price of Cheapest Item |
Required |
Not needed |
Use Price of Cheapest Item Not to Exceed |
Required |
Not needed |
Use Percentage of Cheapest Item Not to Exceed |
Required |
Not needed |
Use Price of Most Expensive Item |
Required |
Not needed |
Use Percentage of Most Expensive Item |
Required |
Not needed |
Use Price of Most Expensive Item Not to Exceed |
Required |
Not needed |
Use Percentage of Most Expensive Item Not to Exceed |
Required |
Not needed |
Use Percentage of Selected Items Not to Exceed |
Required |
Not needed |
Use Price of Equal or Lesser than |
Required |
Required |
Use Price of Equal or Lesser than Not to Exceed |
Required |
Required |
Use Percentage of Equal or Lesser than |
Required |
Required |
Use Percentage of Equal or Lesser than Not to Exceed |
Required |
Required |
Use Price of All Eligible Items (Not Available for Coupon Type) |
Required |
Required |
Add day or time period restrictions to an eligibility rule.
Table 8-3 Transactions Affected by Time Restriction Types
| Time Rule Type | Stored Value Redemption | Loyalty Point Eligibility | Coupon Redemption |
Bonus Period |
Affected |
Blackout Period |
Affected |
Affected |
Affected |
Activate Blackout Period |
Affected |
Birthday Anniversary |
Affected |
Signup Anniversary |
Affected |
Consecutive Period |
Affected |
Active Period |
Affected |
Affected |
