This part of the Oracle MICROS Forecasting and Budget User Guide is intended for system administrators. A system administrator uses enterprise business requirements to configure and schedule events at either the organization level or at the location level.
Events are occurrences that might affect business trends. You can generate impact analysis reports and incorporate events into forecasting to calculate the impact on business trends and to generate accurate forecasts for non-standard business days.
