If more than one profile is assigned to location/revenue center, then you must use the Advanced View.
Table 2-1 Forecast View Parameters
| Parameters | Description |
 Location  |
 Specify the location for the forecast you want to view or adjust.  |
 Revenue Center  |
 Specify the revenue center for the forecast you want to view or adjust.  |
 Week  |
 Specify the week for the forecast you want to view or adjust.  |
Table 2-2 Forecast Components Information
| Column | Description |
 Forecast Components  |
 Lists the available forecast components.  |
 Forecast  |
 Displays the forecasted values for the forecast component  |
 Adjusted Forecast  |
 Displays the adjusted forecast.  |
 Cumulative Adjustment Percent +/-  |
 Shows the percentage of adjustment. Increases are shown with a plus (+) symbol and decreases are shown with a minus (-) symbol.  |
 Cumulative Adjustment Amount +/-  |
 Shows the monetary amount of adjustment. Increases are shown with a plus (+) symbol and decreases are shown with a minus (-) symbol.  |
 Actual  |
 Displays the actual amount of the forecast component.  |
 Rating  |
 Displays the rating, based on the configuration of percentages in the Forecast Performance section of Forecasting Admin.  |
 Reason  |
 Shows a reason if the rating requires a reason.  |
Table 2-3 Forecast Adjustments
| Field | Description |
 Reason Category  |
 Select a reason category for the adjustment.  |
 Reason  |
 Select a reason for the adjustment.  |
 Adjustment %  |
 Enter a percentage amount or a monetary amount by which to adjust the component. Enter a minus sign before Adjustment % to produce a decreased forecast. If you enter a value in the Adjustment % field, the Adjustment Amount will update, and vice versa. If you adjust one component, any components with a linked relationship will also update; for example, if Net Sales and Discounts have a 1-to-1 relationship, meaning that whatever amount/percentage Net Sales is adjusted, Discounts will be adjusted by the same, then, when you enter a 15 percent adjustment for Net Sales, Discounts will also be adjusted by 15 percent. This relationship is established in Forecast Profiles. If there is no relationship(s), then only the one forecast component will update.  |
 Adjustment  |
 Enter a percentage amount or a monetary amount by which to adjust the component. Enter a minus sign before Adjustment to produce a decreased forecast. If you enter a value in the Adjustment % field, the Adjustment Amount will update, and vice versa. If you adjust one component, any components with a linked relationship will also update; for example, if Net Sales and Discounts have a 1-to-1 relationship, meaning that whatever amount/percentage Net Sales is adjusted, Discounts will be adjusted by the same, then, when you enter a 15 percent adjustment for Net Sales, Discounts will also be adjusted by 15 percent. This relationship is established in Forecast Profiles. If there is no relationship(s), then only the one forecast component will update.  |
 Comment  |
 Enter a comment to explain the adjustment.  |
Related Topics
Parent topic: Using Forecasting and Budget
