The purpose of the Inventory Management mymaster database is to give an Administrator of a multitenant environment the option to configure the link between Reporting and Analytics and Inventory Management. Reporting and Analytics Web Service is then able to split incoming Web Service Payloads identified by OrganizationID to the corresponding Inventory Management.
To maintain this table, see the internal Inventory Management/Organizations Tool Reference, with My Oracle Support Doc ID 2731231.1.
For this a shell database need to be loaded. The suggested user name is MYMASTER.
Follow the steps in Oracle Database User Creation for Inventory Management and Loading the Shell Database for the New User to load the mymaster database. This database is not used as customer production database, so you may use metric or imperial unit system for this.
Parent topic: Inventory Management Appendix
