The steps below document how to add the Inventory Management portlet, enable a location, complete the sync, and validate the settings.
- Sign in to the organization.
- Click Admin, click Portal, click Portlets, and then click Portlets.
- Click Add and then complete the fields:
- Enter a name.
- Select Portlet.
- Select myinventory.
- Enter a description.
- Set Effective Date.
- Click Save.
- Click Cancel.
- Click Roles, click Portlets, select a role, and then click Configure.
- Click Add.
- Select the myInventory Portlet, click Side Menu Title, and then click Sort Order.
- Click Save.
- To enable the locations that will be using Inventory Management:
- Click Admin, click Portal, click Organization Structure, and then click Locations.
- Select a Location, click Edit, and then click Enable Inventory.
- Complete the sync:
- Navigate to Admin, click Warehouse, click Miscellaneous, and then click myinventory Sync.
- In the Choose Subject field, select Organizations, and then click Sync.
- Repeat Step 10 with Users and then click Sync.
- Validate the settings:
- Sign out of Reporting and Analytics then sign back into the Organization.
- Navigate to the Inventory Management side menu and then access Inventory Management.
