Micros MSA
Simphony Managed Organization
TSR Template Organization
Simphony 2x Template Org
You can log into the template organizations using the sys admin credentials and set configurations such as the side menu, users, roles, and portlets. You can then import the configurations from the template into a new organization. You cannot import configurations into an organization more than once.
Parent topic: Post-Installation Configuration
