install_ version.exe to the Alert Engine server, and then double-click the executable to launch the installation wizard. Do not extract the file to a folder structure that contains spaces.The wizard creates and names folders using incremental numbers. For example, RTA_1, RTA_2, and RTA. The latest backup folder does not have an appended number, and the wizard only stores up to three backup copies.
| Oracle Database | Microsoft SQL Server |
Table 8-6 Alert Engine Configurations
| Field | Description |
Push alert service username and Push alert service password |
Enter the login credentials for the push alert service. |
Number of alert threads |
Enter the number of alert threads. |
Portal DB User and Portal DB Password |
Enter the Enterprise Back Office database login credentials. |
Core DB User and Core DB Password |
Enter the core database login credentials. |
Location Activity DB User and Location Activity DB Password |
Enter the location activity database login credentials. |
RTA DB User and RTA DB Password |
Enter the RTA database login credentials. |
CE DB User and CE DB Password |
Enter the CE database login credentials. |
Normal: Review the install folder, features, and disk space requirements.
Advanced: Review and edit individual variables in the installation files, then review the install folder, features, and disk space requirements.
C:\temp\ folder during installation, and to the installation path after completing installation.Related Topics
Parent topic: Enterprise Back Office Components and Services
