For Oracle internal use during Oracle Cloud installations.
Allows for the configuration of the translation between Reporting and Analytics and Inventory Management Web service.
- Create the folder
root\Inventory Management\log\myOrganization\ to store the Inventory Management web application log files.
- In the latest Inventory Management release 9.1 patch installation media, unzip
<date>_HIM_myOrganizations_9.1.x.x.x.zip in <drive>:\IMSetup.
- Create the folder
myOrganizations at c:\inetpub\wwwroot\.
- Copy the contents of
<drive>:\IMSetup\<date>_HIM_myOrganizations_9.1.x.x.x\ HIM_myOrganizations.Application to c:\inetpub\wwwroot\Organizations.
<drive>:\IMSetup\<date>_HIM_myOrganizations_9.1.x.x.x\ HIM_myOrganizations.Config to c:\inetpub\wwwroot\myOrganizations.
- Navigate to the Internet Information Services (IIS) Manager and click Server Name, click Sites, click Default Web Site, right-click myinventoryWebServices, select Convert to Application, and then select DefaultAppPool.
- Navigate to
c:\inetpub\wwwroot\inventoryManagement and launch WebConfig Wizard.
- Move the
web.config folder from c:\inetpub\wwwroot\myOrganizations to the Web.Config Wizard
- In Web.Config Wizard, click Database Connectivity, and then complete the fields:
- Click Login and Menu and in the Organizations field, enter the short name for the organizations as defined in Reporting and Analytics. This is also the Oracle Database user.
If left empty, you must enter the short name each time you sign in. If there are multiple organizations, separate each with a comma and you can select one when signing in.
- Click Files and Paths and in the Log Path field, enter the path to the log folder created in Step 1.
