Book invoice to B/O: This job processes invoices which are set to Booked to Accounts Payable within the Invoicing module if configured. Afterwards an export file or files can be generated which can be used by an accounts payable solution.
Book sales from myInventory: This job handles stock depletion based on sales when booking sales manually within the Maintenance | Booking Sales module.
Close financial period export per client: This job creates export files when closing the financial period per client within the Closed Financial Period module if configured at Maintenance | Settings | General and scheduler is activated for export at Master Data | Clients.
Close financial period export per location: This job creates export files when closing the financial period per location within the Closed Financial Period module if configured at Maintenance | Settings | General and scheduler is activated for export at Master Data | Clients.
Import Master data: This job processes Master Data when consuming the Master Data Web Service. However, this job is not used when using the Master Data Web Service Delta call.
Sales History Compression: If configured in the Organizations web application, this job aggregates sales inventory item activities per day. For example, if bottled watered was sold 200 times per day per restaurant, then this job will turn the 200 inventory item records which are linked to the sales item into one record with a quantity of 200 which reduces the table size.
Send Notification: This job sends Scheduler notifications after a job has been completed if configured at the Maintenance | Scheduler module.
Send Vendor Discrepancy: This job sends an email with discrepancy information between ordered and received quantities when using the Vendor Rating functionality in Receiving.
Send Vendor Rating: This job sends an email with Vendor Rating information when using the Vendor Rating functionality in Receiving.
