root\Inventory Management\log\IM_Organizations\ to store the Inventory Management/Organizations web application log files.web.config file from <drive>:\IMSetup\Patch91x\<date>_HIM_myOrganizations _9.1.x.x.x\HIM_myOrganizations.Config to replace the file in c:\inetpub\wwwroot\myOrganizations.c:\inetpub\wwwroot\myOrganizations and launch WebConfig Wizard.web.config folder from c:\inetpub\wwwroot\myOrganizations to the Web.Config Wizard.Brand — select Oracle.
Server — enter the Oracle instance name.
To support multitenant use of the web application, all database users for Inventory Management must have the same password.Note:
If left empty, you must enter the short name each time you sign in. If there are multiple organizations, separate each with a comma and you can select one when signing in.Parent topic: Install Inventory Management/Organizations
